CAB REMOVAL
CAB REMOVAL
This is probably a dumb question but how do I remove the cab from the frame? What holds it to the frame? I cannot find any bolts on my 1968 F-100 Ranger
re: CAB REMOVAL
There are four bolts. The rear two are underneath the fuel tank (assuming you have an in-cab tank.)
The front two are accessed by removing two plates (one on each side) on the front cab mounts.
