Project:Light up hood emblems DialupWarning: Lots of photos
No tech discussion, please
FLATBEDFORD
Re: Project:Light up hood emblems DialupWarning: Lots of photos
Post by FLATBEDFORD »
Its gonna look great with the roof lights. Just make sure that they don't look like the truck on the left.
Steve
1970 F350 DRW Factory 9' Platform/Stake, 360, T18.
Passed on to new care taker July, 2013
My Photo Gallery
http://s115.photobucket.com/albums/n298/flatbedford/
MadMaxetc
Post by MadMaxetc »
That looks realy great!
I have a plan for the LED version...I will draft something up and post it later tonight.
It should only require a small hole in the hood.
Dan
Project: '63 F-100 LWB / 460 / C6 / 2x4 / Work In Progress!
Daily Driver: '67 F-250 Converted to F-100 LWB / 300 / T-5 / 9" 3.70:1 / 235/75R15 Tires
1/4 mile in 17.64s @ 75mph (it's 4200lbs!!!)
"Work Harder! Millions On Welfare Depend On YOU!!"
FORD Girl
Photobucket Pictures
MadMaxetc
Post by MadMaxetc »
OK so here is my take on how you could do the LED Marker light.
Instead of pointing the LEDs out you could make a Relector Lens that takes up less space and uses fewer LEDs.
** Disclamer **
I do not have these on my '67 so I have never made them.
I have no idea how deep, wide, long or tall the Marker Emblums are.
Here are the steps:
  1. Disassemble the marker emblem as stated above.
  2. Remove reflector and the backing as stated above.
  3. Take a .25" thick peice of Acrilic Clear plastic. (see disclamer) Cut it so that it fits inside the reflector, but not smaller than the opening you see in the Emblum.
  4. On the AFT side drill 3 hols just big and deep enough for the LEDs to fit in. (Don't install yet, just fit check)
  5. On the Front (bid side that will face out) cut some long groves paralell to the short side using a hacksaw or dremmel. Lay the blade at an angle so that it cuts a V not a knotch. This will "Let the Light out" of the acrilic.
  6. On the outside and the back use some clear finger nail polish to smooth the ruff sides out. DO NOT do this to the groves. Also put a little in the hols for the LEDs (not to much, they still need to fit in there!)
  7. After tha polish dries, put some reflective tape on the back and sides. The smoother the better. This will help ALL the light go out the front.
  8. Now install the LEDs into the holes, using a little hot glue on the outside.
  9. Solder them up with the propper resistor to a short run of wire. (you could get fance and put a nice connector on there)
  10. install the Reflector into the Emblem.
  11. Using a little Hot Glue, Put you Acrilic Lens on the back of the reflector and glue it down. Don't gle on the front, this could create dark spots.
  12. Install on truck! (should only need a small hole for the wire to pass through.)
For those who only need a picture... (click to make bigger)
(Green is the LEDs ) (Grey is the Acrilic) (Blue is the Reflective tape.)
Image Image Image
For LEDs you can just get some at Radio Shack or http://www.superbrightleds.com/leds.htm#threemm. You should use the 3mm ones to keep the Acrilic as thin as you can.
For info on how to pick the right resistor look here http://led.linear1.org/led.wiz
I used the values from here http://www.superbrightleds.com/specs/w3mm_specs.htm of 3, 3.6, 20, and 3.
What do you guys think??
Dan
FORD Girl
MadMaxetc
Post by MadMaxetc »
If anyone wants to send me a Side Marker I will do this for free if you pay for shipping. It looks like fun.
Dan
FORD Girl
rjewkes
Post by rjewkes »
i have a set you could try on.
fuelly.com
knightfire83
Post by knightfire83 »
Very interesting MadMaxetc. It will be interesting how this one turns out.
I have 1 suggestion though, I think you had better use a clear epoxy to assemble the thing instead of hot glue.
On a hot summer day I think the hood and emblem could get hot enough in direct sun to melt the hot glue.
1974 Ford F-100 4x4- 360 / manual.
1970 Ford F250 4x4 ~ Sold.
MadMaxetc
Post by MadMaxetc »
rjewkes wrote:i have a set you could try on.
PM sent.
Dan
FORD Girl
rjewkes
Post by rjewkes »
one more thought, how about another set that works with the flashers? With a tiny transistor that'll make them pull like a normal bulb, with the first 3 on at night, the second three would make it brighter when the emergency or turns are on? and be bright enough for daylight as turns.
fuelly.com
MaxKlinger
Post by MaxKlinger »
very cool, good job! I might take a crack at this someday, too. However I'm going to come up with a way to do it without cutting the hood.
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
cdeal28078
Post by cdeal28078 »
I like it a lot. I think I actually like the clear lenses in the day light also. I might have to get me some clear turn signal lenses also. Nice job.
Another option would be to turn them into a turning light. Like the Town Cars had. A clear light that came on with the turn signal to light up the side of the road so you can see the driveway or road you are turning into.
I like that idea. I never realized how much that help until I sold the old 88 Lincoln Town car I used as a road car when I traveled for work. That light made a nice difference when I turned into a dark driveway late at night.
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
rjewkes
Post by rjewkes »
:yt: had them on a 95 olds 88 royale.
fuelly.com
knightfire83
Here's my last pic of it in the day time, with the cab marker lights
Now all it needs is nerf bars and bed rails.
rjewkes
Post by rjewkes »
if only the markers uptop could b e clear without having to be sun damaged or aged.
fuelly.com
Happy_Camper
Post by Happy_Camper »
What an awesome job!
One of the cool things about using the clear lens, is that, anyone who knows bumps, would know something cool is going on there. The light really fanned out well.
Thanks for the very detailed post. Two big "Gear-Head" thumbs up!
Scott
1972 F250 Explorer C/S, 390-2V, Dual exhaust, C6, Goose neck ball in bed
New and improved with Tilt Wheel, Intermittent Wipers, 2005 Bench seat and 5th wheel camper!...
Life is *very* good!
FLATBEDFORD
Need a night time shot with the cab lights.
Steve
My Photo Gallery
