Ever wonder why a curicuit tester has a point on it?
Merlin68F100
Post by Merlin68F100 »
Guy stops me in traffic the other day and tells me I have no break lights. So yesterday I figure I will get it fixed.
The testing,
All lights work, accept the break lights.
4 way flashers work.
Turn signals work.
So I ground my spark chaser and touch the hot side of the break switch, lights on.
I press the peddle and touch the other side of the break switch, lights on.
Must be the wire to the rear of the truck.
Long story short I look\feel\wiggle my way back to the tail light buckets. Remove the buckets and clean the grounding contact points before reinstalling them.
So now its 95 deg plus and I am back in the cab scratching my brain. :? I figure why not replace the switch, its got to be original equipment, and for a few buck I can be sure the issue is somewhere south of the switch.
When I start to remove the switch the wire to the tail light doesn't move like the wire on the other side. I close the switch and touch the contact AGAIN....lights on. Then I stab the wire 2 inches up the line. NO LIGHT!!!!! the wire had broken right at the stake-on but the insulation was still holding onto the crimp.
And that, boys and girls, is why there is a pointed end on the circuit tester. Thank you, and good night.
"A point in every direction is the same as no point at all."
The Pointless Man
Heavenlyfire
Post by Heavenlyfire »
glad you found it, wanna come help with all my lights lol.
crazy larry
Post by crazy larry »
i always thought it was so i could stab myself in the leg or titty when i put it in my pocket???
glad you found it with no puncture wounds to yourself.
Larry
'72 F-250 Kustom 396 c.i.
Fotoes
OLEYELLERTRUCK
Post by OLEYELLERTRUCK »
I thought that point was to make my fingers bleed!
I will have to try that use for it!
shrektruck
re: Ever wonder why a curicuit tester has a point on it?
Post by shrektruck »
:eek: It's not fer digging the corn outta yer teeth after the tailgate party at the tractor pulls???
flyboy2610
Post by flyboy2610 »
crazy larry wrote:i always thought it was so i could stab myself in the leg or titty when i put it in my pocket???
Been there, done that! :lol:
Red Green
you'd better be right.
willowbilly3
Post by willowbilly3 »
OLEYELLERTRUCK wrote:I thought that point was to make my fingers bleed!
Me too, I thought it was for my routine blood letting. Then I got smart and got one of those little plastic clothspin thingys that hols the wire and gives a small hole to probe through.
