ANOTHER good afternoon in the shop! [LG PICS]
Actually got a lot done today. Felt good to spend the day just getting my hands dirty for the first time in about a month. Not only did I get the firewall coated with POR-15 and painted, but I was able to get started on mocking up the front sheetmetal. I just posted another project update page at http://www.fordification.com/my67-p47.htm with additional pics.
Actually starting to look more like a truck again, isn't it?
- trukcrazy
re: ANOTHER good afternoon in the shop! [LG PICS]
Looks good. You will be it soon.
John, #424
1967 F250 crewcab x 2.
2010 Dodge Ram 1500 Sport Quadcab
2008 Challenger SRT8
- 71-F-250SC-72-F-250C
Man Keith, your truck is really starting to come together. I remember when we were at about the same stage. Which is pathetic for me and my dad because we dont have the rust issues you had with finding a decent cab. Looks good
Stephen
Stephen
71 f-250 Sport Custom-frame off in progress..again thank to irjetmachanic.
72 f-250 Custom
71 f-100 swb sport custom
03 mach1 mustang
cant forget my thing...haha 74 volkswagon thing.
[quote="ToughOldFord"]
Damn, 7 gallons per mile, obviously FE powered!
72 f-250 Custom
03 mach1 mustang
- customcrewcab
so what color are you going to paint this truck, and what motor and tranny?
http://www.fordification.com/galleries/ ... ?cat=10106
if theres a new way, i'll be the first in line. it better work this time
1970 crewcab 393w afr heads, 6 speed, turbocharged, 6 piston calipers 13" rotors on all 4 corners
Re: re: ANOTHER good afternoon in the shop! [LG PICS]
To be honest with you, I haven't really nailed down the color yet. When I first started this project I was planning on going with a semi-flat black and having the truck almost completely de-chromed. However, after seeing a few trucks painted that way I'm not entirely sure I want to go that route now. If I decide against it, it'll probably be Rangoon Red, just like the pic in my sig. If I go with the red, I'll be installing an aluminum grille and side trim.customcrewcab wrote:so what color are you going to paint this truck, and what motor and tranny?
As for the drivetrain, I'll be using a 390/C6 combo...mostly stock, since it'll be a daily driver. However, I'll install headers and dual exhaust and an Edelbrock carb on the stock intake (unless I opt for a Performer RPM).
- dduude
Looks good enough to drive now Dude
- flyboy2610
Looking good, Keith! You'll have her on the road in no time!
Red Green
you'd better be right.
Red Green
- 4x4x4crewcab
Keith
That is looking good. I can relate to that repair Are you going to assemble the whole front before dropping in the engine? or is that strickly for alignment purposes. I'm watching your every move
Mark
1970 Ford F-250 Crew Cab 4x4 short box
1969 Volkswagen Karmann Ghia
1999 Ford Windstar
1983 Chevrolet Silverado p/u
1990 Lincoln Town Car
1998 Lincoln Town Car
Does your truck need emblems? Check out http://www.onceuponapart.com
1999 Ford Windstar
Yeah Mark, I just saw your update too....looks like we're on about the same chapter of our truck's resurrections! Yours is looking good as well!4x4x4crewcab wrote:...That is looking good. I can relate to that repair. Are you going to assemble the whole front before dropping in the engine? or is that strickly for alignment purposes. I'm watching your every move...
Tentatively the plan is to assemble all the front-end sheetmetal to get everything lined up and tightened down. Then I'll probably remove the radiator support to allow me access to install the engine/tranny combo, so I won't have to raise the boom so high to clear things and risk damaging my bee-yew-tee-full paint job.
- 69F110
Well, I spent the day in the shop, but didn't have the camera nor did I really get enough done to put together an update page anyway, so I'll just post my progress here.
I started out rounding up all the fender bolts and got them poked into a cardboard box with the heads sticking up, and then sandblasted and painted them. I also sandblasted and painted the radiator support shims in case I'd need them when I start aligning stuff.
I then got started getting the front fenders cleaned up. I spent almost 2 hours cleaning the rubbery undercoating off one fender before noticing that it had a rust hole in the typical area behind the wheelwell. So I tossed that one aside and grabbed another that was from the 27,000-mile '67 CS I recently parted out. The fender was rustfree but had a few dings in it, so I spent a little time getting them tapped out. They're almost perfectly smooth now, so it'll just take a very thin coat of filler to make it totally straight.
I then got the backside of both front fenders cleaned up with the angle grinder, alternating between the composite stripper wheel and a wire wheel attachment. When I'd gotton about as far as I could go with the grinder, I got started sandblasting the back. Got one fender about 80% done before having to come home for the night.
I'm not sure when my next day in the shop will be, but I should be able to finish cleaning up the backside of both front fenders and get them painted with POR-15....and then the front-end assembly will commence.
- flyboy2610
Sounds like it's really coming along!
Congrats, Keith!
Congrats, Keith!
Red Green
Red Green
- Merc Man
Sounds like its coming along great Keith I've seen ragoon red on a 62 Galaxie 500 (factory color) .It will look great on your truck !
Truck : 1968 Mercury M100 Custom Factory Ordered 360 v8 , Cruise-0-Matic, Camper Special leaf & Spring Package .
- campfire67
If anybody has a picture of a nicely painted rangoon red I would like to see a pic because that is the factory color of my truck and I am considering on using that color when I get there
Life is to short to worry..... be happy
