Fitting
- OldRedFord
Fitting
I need a fitting like the one in the link, but the threaded end needs to be male inverted flare.
Is there such a thing?
http://fittingsandadapters.com/pusbarmalpip.html
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
- Ranchero50
Re: Fitting
Depends on the application. Inverted flare usually gets a good bit of pressure. Those push on hose bibs don't even get s clamp installed when you use the correct hose...
What's the application?
Re: Fitting
They're made but not common, 5/16 and 3/8 are the most popular. The fittings on inverted thread are straight SAE instead of tapered pipe like your example. What size do you need and whats it for?
- OldRedFord
Re: Fitting
Needs to be 5/8-18 thread and a barb for 3/8 hose. It is for my Holley carb. After the whole deal with the chrome fuel line and asking around about it online I will just go with rubber hose for now.
Tim
- BobbyFord
Re: Fitting
Like this?
- OldRedFord
Re: Fitting
Yup, just what I am looking for.
Tim
- BobbyFord
Re: Fitting
I've got them for 3/8" and 5/16" hoses. They are available at your local parts house (O'Reilly's, Napa, CarQuest, etc.)
Let me know if you can't find one, I'll send you this one.
- OldRedFord
- BobbyFord
Re: Fitting
S.A.E. inverted flare hose fitting
Or...
http://www.summitracing.com/parts/SUM-M08099/
http://www.summitracing.com/parts/MRG-1543/
http://www.goodyearrubberproducts.com/f ... age257.pdf
Or...
- BobbyFord
Re: Fitting
I think the "MRG-1543" Summit link might be the way to go for you.
- OldRedFord
Re: Fitting
So that would thread right into the bowl instead of using the fitting that is there now to reduce down? Like in your picture above.BobbyFord wrote:I think the "MRG-1543" Summit link might be the way to go for you.
Tim
- BobbyFord
Re: Fitting
Yes, if you click on "application" on the Summit link it says it fits Holley and Rochester carbs. Holley fuel bowl is 7/8-20 thread.OldRedFord wrote:So that would thread right into the bowl instead of using the fitting that is there now to reduce down? Like in your picture above.BobbyFord wrote:I think the "MRG-1543" Summit link might be the way to go for you.
- OldRedFord
- BobbyFord
Re: Fitting
No problem. Git that dang thing runnin' so we can all hear it!!OldRedFord wrote:Cool. Thanks for the help.
- OldRedFord
Re: Fitting
Some of you are living vicariously through my build.
Tim
