How do you remove the outer panel (see pic) from the tailgate? I wanted to take it off for painting... is that recommended?
I tried pulling it and popped some kind of weld I guess (see pic). How do I fix this?
Thanks.
Tailgate panel question
- kentdaryl
re: Tailgate panel question
Mine was pop riveted from the inside of the tailgate. Just drill out the heads of the rivets and it should come off. I reinstalled it with pop rivets too.
Daryl
Daryl
- flyboy2610
Oops!
Red Green
you'd better be right.
Red Green
- 71-F-250SC-72-F-250C
I am having a simular problem, but I am trying to install one of those peices on a tailgate that has never had the trim on it. Am I going to have to try to drill holes in my tailgate to get the holes in the trim to line up, so I can pop rivet them in?
71 f-250 Sport Custom-frame off in progress..again thank to irjetmachanic.
72 f-250 Custom
71 f-100 swb sport custom
03 mach1 mustang
cant forget my thing...haha 74 volkswagon thing.
[quote="ToughOldFord"]
Damn, 7 gallons per mile, obviously FE powered!
72 f-250 Custom
03 mach1 mustang
Mine was pop-riveted too. Is that how they were originally installed?
The Landlord: "Are you guys starting an automobile repair shop out of my house or something?"
"No, these are all our cars."
"The three of you have eleven cars???"
Yes, they were all pop-riveted. Sometimes if a rivet broke loose a previous owner might have used a regular sheetmetal screw instead. I've removed a few of these panels which were about 50/50 mix of screws and rivets.
For mounting one of these on a tailgate which didn't have one originally, I'd make a template to use for figuring out where your holes need to be drilled. You can either:
1) lay a long sheet of paper over the top of the panel and trim out around the edge, then mark the hole locations. You'd then center your template on your tailgate and mark where where you'd need to drill.
2) Spread some marking paint on the rivet eyelets on the back of the panel, and then just press the panel where it needs to be on the tailgate and remove it. The marking paint should leave impressions on the tailgate where you'd need to drill.
- 67effie
I did option #2
If at first you don't succeed. Get another beer.
Jeremy
1972 F-100 - currently under going complete frame off restoration
1997 Mustang GT Convertible- (gone but not forgotten, damn unemployment)
1996 Saleen S281 #247
1988 - Coupe, OSP car sold to public NEW, under construction, 1 of 3 that was supposed to go to Saleen in 1988.
http://www.fordification.com/galleries/ ... ?album=270
Jeremy
