390 long block to rebuild, cheap
- Kurt Combs
November 1968 casting date on a 390, with "S" four barrel intake manifold. Turns over freely and all the valve move up and down when tapped with a hammer (my test that they aren't bent). Crank has 2U on it and a square notch in the flange where the flex plate bolts on. I believe these two things confirm it is a 390. $200 to a good home (on Craigslist for $250 so mention you saw it on Fordification.com!). I'd really like it gone by this Thursday if possible.
Kurt
1972 F-250
1972 F-250
