Straight Rod Throttle
Moderator: Ranchero50
- jor
What's everyone doing to replace the christmas tree throttle mechanism. How are you hooking up a straight rod? Thanks.
jor
jor
- 460 crew
Yes sir a straight rod fom the pedal linkage to the carb. Ford had a couple variations of adjustable rods that had threads. Might have one in the garage if your interested.
- 460 crew
re: Straight Rod Throttle
I made the one for my 460 out of threaded rod and cut to the right lenth and have heim joints on each end with some jam nuts so they dont back off. Works great!
I'm using the straight rod from a '74 (I believe):
ok, if that works, why did ford make the rube goldberg of throttle linkages to begin with? why not just a cable? the parts truck i have has a cable, but its 6. dose any one know if the bracket will work with the 390?
"I'll fix that later"
- Heavenlyfire
I agree, a cable should work as long as your return springs are good. I had to make a rod for mine (quickly) when the original broke. It may not look great but it works and it is adjustable.
- jor
Hmmmm... that looks like a real easy fix, either the rod or a cable. I'll post after I get it rigged up. Thanks to all.
jor
jor
- heep70
I use a cable. http://fordification.com/forum/download.php?id=2025
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- jor
Heep, your solution is simplicity itself! I guess the trapeze was just some frustrated engineer's idea of a good time.
jor
jor
- 460 crew
Re: re: Straight Rod Throttle
tcb1969 wrote: You can also create a very "touchy" accelerator pedal that will launch the vehicle instead of slowly accelerating it.
John
Sweet that just what I was wanting.
- jor
TCB, thanks for an excellent explanation. I found a rod off a newer model at the wrecking yard and it works fine but now I'm going to evaluate its performance with your comments in mind. Here's a photo of the rod I installed.
jor
jor
Dang Jor - are you building a show truck? That engine looks awesome!
I don't think you'll have any problem with a straight rod - since your going all edelbrock. I'd bet the fuel delivery is a lot more accurate than a stock autolite - not to mention your intake being much, much better!
Just for info - try it both ways though and see if there is any difference?
John
John
- Sharkdance
Excellent post TCB! Thanks for the explanation.
I didnt know the trapeze had such purpose.
My 70 FE has a length of coat hanger for a throttle linkage. Just cut the right length and bend the ends arount to loop/hook the pedal rod and carb linkage together. Doesnt look very technical or fancy, but it works.
