2wd should i lift or do a 4x4 swap?
67_F100
Post by 67_F100 »
i have a 2wd 1967 ford f100 ranger/ camper special with a 352 FE engine......i have heard this truck is rare......should i just lift it and put 35"tires on it or should i do a 4x4 swap.....allso for a 4x4 swap what would i need to swap and from what year truck to mine
thanks
Song references a bump if you listen to when the truck is bought.
http://www.youtube.com/watch?v=0leWmtd6Fww
HIO Silver
Re: 2wd should i lift or do a 4x4 swap?
Post by HIO Silver »
67_F100 wrote:i have a 2wd 1967 ford f100 ranger/ camper special with a 352 FE engine......i have heard this truck is rare......should i just lift it and put 35"tires on it or should i do a 4x4 swap.....also for a 4x4 swap what would i need to swap and from what year truck to mine
thanks
It ain't rare.
Converting a 2WD to a 4WD is doable but it's alot of work. Most will say simply get a 4x4 to start with.
Read these for background.. the principles are the same. Then evaluate if you have the time, facilities, tools, money, and know-how.
2WD to 4WD Conversion
4WOR Magazine: Project Two-by Four (4x4 Conversion)
FTE Thread: Quadrazer's F350- 2WD to 4WD Conversion...
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
towtruckerfour
Post by towtruckerfour »
When I did mine, I had a 70 2wd and a 68 4wd. It was pretty easy to put the 70 body on the 68 frame. I used my engine puller to swap everything. The cab was the hardest part.
Troy
Why is it that the trucks are always the best running vehicles in the family?
Ford means "found on road daily"
70 F100 Custom-352 w/68 Highboy 4x4 frame. My play/project truck
70 F250 Explorer-390/C6 auto. My work truck
04 Mitsubishi montero-family car
