Many years ago a mechanic taught me this;
After removing the wheel-bearing races, sand the outer circumference on a disc sander until it's a slip fit into the hub.
These took about 20 rotations with gentle pressure against the sander until it would slip into the hub with a little play.
Use the thicker end of the ring for hammering, some easy tapping and drive them in. Works really well!
Make your own: Wheel bearing race installers
- sargentrs
Re: Make your own: Wheel bearing race installers
Great idea! Thanks for posting.
- tbone6
- ToughOldFord
Great tip!
1969 F250 Ranger Camper Special. 390, NP435, 3:73s.
That government is best which governs least, because its people discipline themselves. -Thomas Jefferson
Be sure and sand it. When I was young and dumb I did this and it was really hard to get out.
- 1972hiboy
this is a great idea. I use a wheel bearing race to drive in the big 9864s seals works like a champ!
Rich
Dont eat yellow snow.....
- HIO Silver
No need to grind.... use a cut-off wheel and cut a slot through one side of the race.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
That's a damned good point there HIO!!!! I personally use a brass drift 90% of the time, but will try this for those times where the final amount to drive it seems a bear to get the drift on the darn race!HIO Silver wrote:No need to grind.... use a cut-off wheel and cut a slot through one side of the race.
2017 Ford Raptor
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
