Turn signal switch
Rockcrusher
Turn signal switch
Post by Rockcrusher »
The turn signal switch in my '69 committed suicide the other night and so far I haven't been able to find an aftermarket or repro replacement. Any suggestions on suppliers . . . Or will I be forced to use a junk yard replacement?
Rockcrusher
http://www.rockcrusher4x4.com
Ignorance is sticking your hand in the fire 'cause you don't know what it is ... Stupidity is doing it a second time.
heep70
re: Turn signal switch
Post by heep70 »
LMC has them I believe for around $12. Do you only need the cam? Pg 122
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
flyboy2610
Post by flyboy2610 »
Dennis Carpenter ( http://www.dennis-carpenter.com/ ) has them.
They are pretty easy to install I had to replace the one on my '68F100.
Rockcrusher
I haven't pulled the steering wheel yet but I would guess that the whole switch mechanism went into rapid dissasembly mode. Thanks for the info.
Rockcrusher
heep70
Post by heep70 »
The cam is what usually brakes
Greg
cobraF100
Post by cobraF100 »
I have one I dont need anymore because I got a Tilt Column..
$12.00 shipping included.....
Chris
Never Forget Our Soldiers
bluef250
Post by bluef250 »
Bought a replacement turn signal switch at local Carquest about $50. I understand that a firm in Colorado makes them. Direct replacement. Almost same wires. OEM Ford sold on eBay for between $10 and $20. Also have seen others between $30 and $45. See eBay Item number: 7935364697 ends 11/23/04.
