Some of my past Ford's - and others
Grease Monkey
Post by Grease Monkey »
'89 Ranger - Shortened wheelbase to 110.5", sectioned bed to match. '79 F100 high pinion Dana 44 in front, 31 spline big bearing 9" in rear - 5.38 gears, spool in rear, welded front. Relocated gas tank to inside bed. 63" chevy leaves with a couple leaves removed in rear, moved inboard. Custom soft rate coils on front for early Bronco. 38.5x16x15 TSL Super Swampers.
Last edited by Grease Monkey on Sun Dec 21, 2014 10:03 am, edited 1 time in total.
Grease Monkey
Re: Some of my past Ford's - and others
It was a blast off road!
Grease Monkey
'93 Mustang GT - Clean inside & out, low mileage all original car that I bought, and mildly modded to make a fun street car.
Another Fox body I had more recently. Big cam - big & littles. Converted it from auto to 5 speed.
Grease Monkey
The other bump side I owned about ten years ago. Bought it with a 429 in it. Put a low mileage 460 bottom end with reworked DOVE heads in.
I also have owned a clean '79 dentside with a 351M. And a solid '66 slickside that needed paint and had a stout 351C. No pics of those scanned. And I have no pics at all of my '69 Mustang GT Sportsroof 302 auto.
Grease Monkey
'94 YJ served as my daily driver and weekend toy for over three years! Had a blast in that thing!
'74 CJ5 360, 3 speed, 4.88 gears, front locker, rear spool, spring over on YJ springs. On board air, full cage, 35" gumbo mudders.
'82 Toyota. Bobbed the bed and made up a custom leaf pack for the front, welded rear, 34x10.50x15 Swamper LTB's. Fun little beater!
Grease Monkey
Combined an '87 4Runner fuel injected engine, fuel tank, and wider rear axle with '85 4Runner frame and solid front axle. Rear locker, 5.29 gears, 36" Swampers.
Also sectioned the spare fiberglass top down to make a custom half cab.
Also just because I think it's a cool pic. The 4.7 in my wifes 03 4Runner when I had the front accessories removed while doing routine maintenance, replacing the timing belt and water pump.
Guess I'm taking a stroll down memory lane this morning going through old pic's. :lol: I'm sure a lot of you other gear heads can relate. :)
AZf100
Post by AZf100 »
Those Are Some Cool Pics. I Had a 89 Toyota with a 3.0 DOHC Was a tough SOB
"I ain't as good as I once was But I'm as good once as I ever was"
https://photos.google.com/photo/AF1QipM ... mfKhMOFcFj
1971 F100 SWB 302 2WD (Work In Progress)
2010 F250 4X4 6.4 Power Stroke / lariat Black
2020 F150 4X4 3.5 Eco Boost / icon Silver
crazyhorse
Post by crazyhorse »
Mr Grease, thank you for the nice pictures. :thup:
(wish I could post em) :(
I have a red (original paint) 93 Mustang GT like yours.
I like it and enjoy it very much.
It is a 5 speed 5.0 with most of the mods but do not have a super charger on it.
It is fun to drive.
Grease Monkey
Thanks guys! :thup:
