1970 F250 4X4 Rebuild / Updating
- hfdco4
Re: 1970 F250 4X4 Rebuild / Updating
I have a question for the 4x4 guys. I am looking to flip the u-bolts on the front axle. Has anyone done this so you can provide a parts list of what I need? I have hung it up once before on the u-bolts while playing and don't want to do it again.
FE390PC
FE390PC
Just curious what your hoping to gain from flipping the U bolts. A previous owner of mine chopped them shorter for more clearance
Kyle
Kyle
- hfdco4
I actually hung the u-bolts up on an obstacle, had to use a pry bar to lift them off. If I flip the u-bolts there will only be the rounded portion of the bolts at the bottom. I may try and design something to protect the nuts like a small skid plate.
FE390PC
FE390PC
- hfdco4
Hope to post some progress pics Monday.
FE390PC
FE390PC
- hfdco4
Got a few things done. Set the new cross member in place and bolted it up. I want to hang the front springs and get it back on its wheels so I can complete the rear tank install.
FE390PC
FE390PC
- hfdco4
Also got more cleaning and painting done on the rear part of the frame.
FE390PC
FE390PC
Those spring perches look good. Your getting close to a finished frame!
Kyle
Kyle
- hfdco4
Getting there. I hope to get some more done this weekend. I have some different frame cab mounts to put in place of the rotted out ones. My problem is trying to clean the gunk and undercoating off them. Anyone have some trips?
FE390PC
FE390PC
You could burn it off with a torch.
Kyle
Kyle
- hfdco4
Oh, that is a good thought. I hope to play in the garage this weekend.
FE390PC
FE390PC
- hfdco4
Got some work done on the rear frame area. Installed the new rear cross member and rear spring shackles. Also did a little more painting on the rear frame.
FE390PC
FE390PC
- hfdco4
I reconditioned one rear spring, hope to do the other on Friday if the weather holds. I have to press in the new spring bushings since no one makes replacement poly bushings. Then I want to hang them on the frame.
FE390PC
FE390PC
- Manny
I hate to say it but the gm tank looks to fit really well. Somewhat better than the other b2 tanks and such i have seen. Enjoying this build keep it going!
- hfdco4
Yes, I was bummed out when the Bronco tanks turned out to be too wide. I was able to get a skid plate for the GM tank cheap too. I finished the last spring Friday. The wife and I spent Saturday afternoon and Sunday morning cleaning the siding on the garage.
FE390PC
FE390PC
- hfdco4
So on travel for work today and tomorrow, hope to get back on the rear springs maybe Friday. Need to clean and paint the small 1" block that will be on there, as well as bend the retaining tabs back down on the spring pack once the new center pins are installed. The graphite paint is very slippery even just to handle the springs. Coverage was pretty good as I used a quart container and a brush to apply two generous coats to the scaled and sanded leaves. For 47 year old springs they were in good shape.
FE390PC
FE390PC
