1970 F250 4X4 Rebuild / Updating
hfdco4
Re: 1970 F250 4X4 Rebuild / Updating
Post by hfdco4 »
I got some motivation for Christmas. My wonderful wife bought me some stuff for the garage. I got a nice welding jacket, File Set, Face Shield and a small Belt Sander. I am a very luck guy for sure!
:fr: FE390PC
Venomous duck
Post by Venomous duck »
Great score. Motivation is the best gift.
hfdco4
Post by hfdco4 »
Got back out into the garage. Made some progress as I found the actual spacer provided with the New Harmonic Balancer. I pulled out the one I made and installed the correct one, belt alignment is perfect now. I moved a tool box and cleaned some stuff of my workbench, so now I have great access to the front of the truck.
:fr: FE390PC
hfdco4
Post by hfdco4 »
Picked up Insulation from Eastwood also grabbed a Flaring Tool while I was there.
:fr: FE390PC
hfdco4
Post by hfdco4 »
Small update and progress. So I finally got back out into the garage. I pulled the Headliner Moldings and sanded the rust off them. I decided to try and paint them a semi-gloss black. They will look good against the ABS Plastic Headliner I have.
Now I can put those aside and start on Cab Insulation.
:fr: FE390PC
Fordkid68
Post by Fordkid68 »
That trim looks great!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
hfdco4
Post by hfdco4 »
Yes, It went from trash worthy to very usable in short time.
:fr: FE390PC
hfdco4
Post by hfdco4 »
Since the trim came out so good, I figured the Brake/Clutch Assyria needed to be done. I pulled it all apart and cleaned it up. I sanded and painted all the pieces. Last week I ordered all the bushings and a new stop from Dennis Carpenter. I do have to weld the Clutch Rod as one end has a groove worn in it. Thursday I am going to start the reassembly. Pictures to come soon.
:fr: FE390PC
hfdco4
Post by hfdco4 »
Here are the before pictures.
:fr: FE390PC
hfdco4
Post by hfdco4 »
With the pedal ass'y painted, its time to pull out the old unit.
:fr: FE390PC
hfdco4
Post by hfdco4 »
Since I made some progress I figured I would keep moving forward. I ordered parts for my power steering pump refresh and also ordered a new sending unit for the rear tank I am installing. Small steps but at least I am going forward for the moment.
:fr: FE390PC
390FE1972
Post by 390FE1972 »
Good to see you are making more progress, it helps motivate me to keep working on my truck. Your clutch and brake assembly looks great! 8)
hfdco4
Post by hfdco4 »
More progress, I pulled my Fuel Tank out of storage. Painted the bottom and tested my Fuel Sender. Found that the sender I had will not work so bought a replacement on Amazon. Made a couple of mods and it's installed. Works with my gauge as well. I got the skid plate down and found that I needed to do some additional cleaning and some recoating. Tomorrow I will get the tank and skip plate fully coated. Once dry I am going to work on the install.
:fr: FE390PC
hfdco4
Post by hfdco4 »
Here are the pictures of the Tank and Skid Plate.
:fr: FE390PC
hfdco4
Post by hfdco4 »
Started getting the upper tank straps located on the frame. Right now I have the tank supported in place so I can drill holes. Small steps, but right now they are at least forward!
:fr: FE390PC
