Basketcase parts final round
- basketcase0302
I pray all here have been bumping along fine. It's time to get rid of some inventory of my 30+ year collection of Ford truck parts. Below is a partial list-but by no means a complete list of what I have for sale, (mostly small parts / no body parts / but please ask if you don't see it) and most parts are used unless specified. Most of this stuff can be flat rate shipped in the small box via USPS for $7.90, (which includes a tracking number but no insurance) insurance usually runs an additional $1.30. Please send me the list of what you'd like and the city / state / zip code / residential or commercial address for an accurate shipping quote.
The larger stuff I can UPS ship if you want-or if your anywhere around Gainesville Florida you can stop in and pick it up.
1) U-joints (one 1/2 ton / three 1 ton 1350 series)-$5.00 each
2) Obsolete dash pocket light (all the repo dash pockets have the opening for it) $5.00
3)Headlight switch (71 will fit many years) $5.00
4)79' blue Duraspark ignition box $5.00 SOLD
5) Moog and Elkin 1/2 ton and 1 ton front twin I-beam king pin rebuild kits $25.00 each
6) Used working 3G alternator $20.00 SOLD
7) Assorted obsolete OEM Ford engine and water pump pulleys (mostly small block-a few BBF) $5.00 each
Fan blade / water pump spacers $5.00 each
9) NOS 250 CI 6 cyl thermostat housing $ 5.00
10) Used Ford OEM coil brackets $5.00 each
11) One used voltage regulator $5.00
12) Used 71' window cranks (loose black knobs) $5.00 pair
13) Used PCV / valve cover 90% plastic elbow connectors $1.00 each
14) Used brass intake manifold vacuum "trees" (multiple port vacuum hose connectors) $5.00
15) 71' used windshield washer plastic tank (mounts on DS inner fender) $5.00
16) Ford OEM coil brackets $5.00 ea. (I have two)
17) Dana 44 shim kit (for gear swap to get backlash set within specs) $5.00
18) Dual gas tank floor mounted valve/switch $5.00 SOLD
19) SBF engine fan belts $5.00 for all three
20) 16 ea 9/16" RHT lugs / 66 ea 1/2" RHT stainless and chrome acorn lugs / 9 ea 9/16" X 2.75 RHT dually wheel studs / 23 ea 1/2" RHT black steel acorn lugs / 8 ea 9/16" X 3" LHT dually wheel studs / 31 ea 5/8" dually lugs $5.00 per "bunch"
21) Ford PS pitman arm $25.00
22) New Champion (I have many other new sets-please ask) spark plugs $10.00
23) Ford SBF / C-4 aluminum transmission dowel $5.00
24) C-6 transmission filter with gaskets $5.00
25) Motorcraft 2150 carb rebuild kit, (complete except top bowel gasket-including a used one) $5.00
26) Wright brand 3/4" X 1" impact socket adapter $8.00
27) Sand blaster hood w tool, (tool needs suction hose easily acquired) $5.00SOLD
28) 3M respirator with new box of 3M prefilters / four new high capacity filters $15.00 SOLD
29) KD Tools engine ring compressor $8.00
30) KD tools engine hone (needs new stones easily acquired) $8.00
31) Ford TFI (80's Ford engines) module wrench $5.00
32) Ford & Chebby, (1/2" & 9/16") offset distributor wrench $5.00
33) Mr. Gasket engine degree wheel $5.00
34) Top post battery terminal puller $2.00
35) Nomex heat proof gloves, (think exhaust work) $10.00 SOLD
36) D44 front axle wheel bearing socket, (I have two) $5.00 each
37) Ford/York AC compressor NOS shaft seal kit (most common place your AC will start leaking freon $10.00 pics coming
Thanks for looking guys and God Bless America and all of you!
Edited 05/30/21'
Edited 05/30/21'
Last edited by basketcase0302 on Sun May 30, 2021 7:28 am, edited 27 times in total.
- hillcountryflt
Re: Basketcase parts final round
which power steering gears do you have?
No chance of a 1975ish pitman arm in your collection.
1971 F100 Custom SB Flareside;
2016 Explorer;
2020 F150
2016 Harley Ultra Limited
2008 Ford Mustang Deluxe V6
2016 Explorer;
2020 F150
- basketcase0302
I believe they are the Ford boxes-and yes the pitman arm is on the 79' box still.hillcountryflt » Mon Mar 14, 2016 11:59 am
Last edited by basketcase0302 on Wed Apr 27, 2016 9:44 am, edited 1 time in total.
- basketcase0302
Am finding more and more parts guys, will be adding a few more in the coming days.
And by all means please don't be afraid to offer anything reasonable that you might need.
- basketcase0302
Still have a lot...of good parts guys.
- 67mann
Got any grill's shot me a pm with some info on paying ya for #26 on your parts list
- basketcase0302
Don't what I I messed up that the site won't tell me when someone replies here, sorry for the delay Jerry.67mann » Sat Apr 16, 2016 4:59 am Got any grill's shot me a pm with some info on paying ya for #26 on your parts list
How bout two postage stamps for item #26?
- ThinLizzy13
- basketcase0302
PM answered.by ThinLizzy13 » Fri Apr 22, 2016 10:51 pm
PM sent
- basketcase0302
Guys (and gals as I remember),
I've added a bunch more pics to the photobucket album of my parts for sale:
http://s240.photobucket.com/user/basket ... t=3&page=1
And I've now got a few bumpside specific tools as well as general mechanic tools for sale here.
I'll try to edit the list above tomorrow morning as well as put prices on stuff and I can guarantee you'll like the prices.
The old adage comes to mind that "you can't take it with you"-so I'm praying I can help a few guys out here that share my love of our old Ford trucks in the process.
- basketcase0302
It's updated folks with a lot...of tools and a lot more parts.
Fill up a box with $5.00 parts easily!
Pm sent
- basketcase0302
PM answered-so sorry for the delay in reply.M-100 » Wed Apr 27, 2016 7:55 pm
Pm sent
- basketcase0302
Lot of good parts still guys.
- TNIceWolf
I could use item # 29
Charlie
Charlie
Presently in the stable
1969 Ford F-350 DRW
1969 Ford F-350 DRW
