Pressure for 235/85R16 E
HOWDY69
Post by HOWDY69 »
For those of you with 235/85R16 load range E what tire pressure do you use in your F250’s when they are not loaded.
69 F250, FE Specialties 410, CJ Valves, RPM Intake, Holley 4150,......10 Smiles per gallon
71 Clydesdale in many pieces; 302 roller motor waiting impatiently
doesn't it say on the tire what the max is?
mine are run at 80 which is the max. i don't change it. because its just another thing you have to do when you want to haul something. i can't seem to get the last project out of my bed before i have to put the next one in.
flyboy2610
Post by flyboy2610 »
fordman wrote:i can't seem to get the last project out of my bed before i have to put the next one in.
:hmm: :hmm: :hmm:
Red Green
you'd better be right.
its hard to keep my bed cleaned out. it an every weekend thing around here.
Ford_Doctor
re: Pressure for 235/85R16 E
Post by Ford_Doctor »
I usually run 35-40 psi unloaded. BTW running high pressures while unloaded not only makes the ride harsher but reduces the amount of traction available.
NM5K
Post by NM5K »
I use those on my 68. I usually run them at
about 55 pounds or so. Thats probably a good
"average" pressure for those. What I do is watch the
tire wear. If you start wearing a bit more in the middle
of the tread, vs the edges, you might have a bit too
much. But it will take a period of time to see that.
I'd prefer to run more pressure than less. Get better
MPG, less drag. More bumpy though... :/
MK
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
