4x4 rearend question....
4x4 & Off-road Forum Archives
Moderator: Doug Comer
wolfpack
Post by wolfpack »
Hey guys have a question, my brother in law was moving down here yesterday and his rearend went out but he made it here at 30 miles an hour and 28 miles to boot. My question is don't i need to get the numbers off the rearend because isn't the gear ratio suppose to be the same as the front gear ratio?. Oh btw it's a 84 ford f150 sorry you know how i ramble...Terry
The dumbest question in the world is the one you don't ask.
Doug Comer
re: 4x4 rearend question....
Post by Doug Comer »
Yes. The front and rear are supposed to match.
heep70
Post by heep70 »
Depends on what year and if it is an f100, F250 or F350. F250s are usually a 4.09 front and 4.10 rear. Some older years have 4.56s. I believe the difference in front and rear needs to stay with in 8% of each other in order to keep from popping R&Ps.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
68half/step4x4
Post by 68half/step4x4 »
If the tags are missing, the ring and pinion should have the number of teeth stamped on them. If you divide the ring gear by the pinion gear, that will give you the gear ratio. [35 divided by 10= 3.50, ect...] You should stay with the same in the front and rear or you will be binding up. Not good!
If it's too loud, you're too old!!!
mrung0wa
Post by mrung0wa »
OH Yeah it really does matter!
Especially if you have a DANA in the front and a FORD in the back!
If you get the wrong Ratio Ring & Pinnion your sure to F' it up Big time (when your/he's in 4wd of course).
Lawrence 8)
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
Leadfoot
Post by Leadfoot »
Your best bet is to get down and dirty and check the pinion, & ring ratio
you should be kind of interested in seeing the damage, and its safety if there was a gear swap prior.
If you can't read the numbers on the ring gear hopefully you can count the teeth on the ring & pinion. divide big # by the little# and thats your ratio. & use the same ratio.
OR check the front diff tag call an autowrecker and give them that ratio and they will tell you the proper rear end gear to use, and more than likely try selling it to you.
WHAT ?
Rockcrusher
Post by Rockcrusher »
heep70 wrote:Depends on what year and if it is an f100, F250 or F350. F250s are usually a 4.09 front and 4.10 rear. Some older years have 4.56s. I believe the difference in front and rear needs to stay with in 8% of each other in order to keep from popping R&Ps.
A 2% front to rear ratio difference is a more realistic figure.
Rockcrusher
http://www.rockcrusher4x4.com
Ignorance is sticking your hand in the fire 'cause you don't know what it is ... Stupidity is doing it a second time.
