1970 F100 Frame and Powertrain Swap (to 07 CrownVic running gear)
- biggurn
Re: 1970 F100 Frame and Powertrain Swap (to 07 CrownVic running gear)
Project Floyd: I do believe the Holley HP EFI is well on the way to being tuned! Assigned the pinout in the programming for the Idle Air Control (IAC) today, fired thr truck and let the truck get up to temperature to retune, runs great!
From there, I moved on to the MSD Atomic Transmission Control Module (TCM). For some reason the TCM is constantly throwing error codes on the Throttle Position Sensor (TPS) side of things. MSD customer service is of zero help, infact I found them to be quite rude (same experience every time I've called in, today was not an isolated event). I find it shocking as they are owned by Holley, but with Holley its been amazing customer service! Today all he kept saying "perhaps you need to buy a new TCM" and after I pointed out it had a total of 1 miles so far, so if it needed replaced it was a warranty, all he could say was "I'm not sure what you want me to do..." Wow, guess he was done for Friday!
I decided to isolate the TCM from the Holley, to do so would require a separate TPS just for it. I decided I'd build a unit just for that purpose. I rounded up a TPS from a 1990 Firebird and set to work. Built a mounting bracket from some 14g stainless.
free image uploading
I machined a trigger lever from a piece of aluminum I had in the shop.
picture uploader
Took a little work, but with it all together, I was able to isolate the TCM, and amazingly, while the TPS will still not calibrate completely (still throws two codes) it will read correctly so the truck is now easily driveable! Stomp on the throttle and it'll spin the tires at the shifts for 1st, 2nd, and 3rd!
90 hours, 1.75 miles, 1 burn out, and ONE power slide!
picture uploader
The Fords:
2016 SuperDuty F350 LWB Crew 6.2L
2019 Ford Expedition Max 3.5L
1993 F350 LWB Crew 460
1988 Ford Bronco II 2.9L
1970 F100 (full frame swap Crown Vic Underpinning, LS Powered, 4L80E)
1968 F250 Highboy (LS Powered, 4L80E)
- biggurn
Project Floyd: Today I worked towards finishing up as much of the interior as I could. Infact, all that remains to do in the cab is to make a new headliner (until I decide its time to buy AC and tear the whole dash apart again!).
So.. in addition to wrapping up the stereo wiring, I also mounted the 6x9 speakers in the cab corners. I decided to have a friend cut a couple of 12"x12" panels with the appropriate sized cut out in the center. His plasma table made very quick work of it! Brought them home and bent them up in the metal brake.
As I wanted them removable, they were mounted with 1/4" stainless bolts and rubber bonded washers.
image upload no compression
host images
To provide an enclosed space for the speakers, I used a set of speaker tubs.
They worked out great! Wired in the AMP and 10" sub and now the truck has some nice bump to it!
I'll try and get the headliner done tomorrow so that next week I can finally start on the box!
92.5 hours, 1.75 miles, 1 burn out, and ONE power slide!
(oh and I went to the DMV and transferred a set of plates, just waiting on a proof of insurance to arrive)!
host images
The Fords:
You are burning through this project (and tires too it seems). Great work.
-Monkey-1
Studmonkeyracing.com
studmonkey@bellsouth.net
- biggurn
Thanks! Honestly, I had planned to be done by now, but we've had such a busy spring, it just hasn't happened!
Project Floyd: Spent some time this morning and made a new headliner. Bought a 4x8x1/8" sheet of MDF, some black vinyl and a can of 3M Super 77 and set to work. I was fortunate to have most of the original that I could just trace for a pattern. For under $30 I had myself a new headliner and the smell of old nasty headliner is gone from the truck!
To appease the law (one of my little brothers is a state trooper) I even made the truck road legal...pending the bed to be completed.
94 hours, 3 miles, one burn out, one power slide, and now road legal!
The Fords:
- biggurn
Project Floyd: New hood hinges! The hood opens and closes super smooth now AND stays open all the way. FYI: they label the hinges backward! LH (driver) vs RH (passenger) is when standing in front of the truck, not sitting in the driver's seat as one would expect. I only know this as I ordered from two different eBay sellers and they showed up opposite of what was listed when purchased. I suspect they have the same supplier and the supplier has it backwards... The truck bed is headed into the shop soon (with luck tomorrow sometime)!
94.5 hours
94.5 hours
The Fords:
This is a really cool read! Excellent work and detailed info!!
I attempted to make my headliner the same way you did but what I ran into was the board was not flexible enough to work in the corners. It began to break. I wonder if there is two different versions of that board? Got my at Lowes.
Also noticed you mess with old lawn tractors. Years ago my dad and I messed with Wheel Horse lawn tractors but got out of it a few years ago.
Cool build!!
Barry
Cool build!!
Barry
- biggurn
Might be that your board was a little heavier? I bought this at Lowes and it was super flexible.
I have around 30 different tractors, starting from small walk behind wheeled and tracked tractors up to 10k lb Caterpillars. We also have Hit&Miss (stationary engines) and all the associated vintage equipment. The truck has been a diversion away from that. Though, the tractor in the background is getting a new engine today so it can attend a show and plow this weekend.
The Fords:
- biggurn
Project Floyd: Thanks to a little help from a YoungFordKid this morning, the box is in the shop! Next week I'll be able to start the chop!
The Fords:
- biggurn
Project Floyd: Chop day! Finally had time to make the cut... lots of measuring and double checking. My biggest concerns were 1st: getting the cut aligned so that it would remove the cut out from the saddle tank filler neck and 2nd: getting the back cut aligned such that I didn't have to remove a cross support. Both worked out as planned!
image hosting no sign up
To increase the strength of the seem I brought a pneumatic flange tool as a simple butt weld is inherently weaker. As the flange tool leaves a 1/2" flange, I subtracted that from my cut. To fit the bed closer to the cab, I cut 14.5", netting a 15" length reduction out of the front.
With a little help from my little brother, we were able to get everything lined up and tacked in place.
capture
Tomorrow I'll work on getting the whole thing welded together.
100 hours
capture
100 hours
The Fords:
I am luvn this build!! You are doing a really good job!!
Barry
Barry
- biggurn
Thank you sir!
Project Floyd: The bed is ready to meet the chassis! Today I welded up the chop, ground the welds, added some body filler, sanded (bought a Ridgid orbital, WOW!), and shot some primer.
screen shot
With that done, I finished off the day by adding a hole in the center to clearance the suspension.
upload png
I go back to work tomorrow, so it'll be a week or so before I get to test fit and build bed mounts, but almost there!
105 hours
screen shot
upload png
105 hours
The Fords:
- Manny
Bed looks good. You got any plans to cut the toolbox down?
- biggurn
I plan to. The frame rail will run right in front of the opening, so it'll be a small tool box, with luck, the jack will fit!
The Fords:
- biggurn
Project Floyd: Moved the truck back into the shop this evening to check the fit. Looks like I'll need to take an additional 2" of the front of the opening, not a major issue. I'll also need to trim the back of the frame rails off, but this was already expected.
The Fords:
- biggurn
Project Floyd: This afternoon I was able to test fit the bed. Everything lines up as planned.
image upload free
The 3rd set of mounting holes fall right on top of the chassis cross memeber that I added for the fuel tank, so with a couple of 2" spacers, those mounts will be perfect. I'll have to build the front mount to span the frame.
image uploader
The 2nd and back mounts will be accomplished via flanges off of the existing suspension kick-up and the soon to be added rear frame cross member... hopefully by the middle of next week, the box will be wrapped up and I can finally get the truck on the road for some miles.
107.5 hours
image upload free
image uploader
107.5 hours
The Fords:
