Not ha-ha funny either!
It shifts fine but a little shaky getting out of first. Even finessing the clutch its a little tricky to get a smooth take off. If I let the clutch pedal about 3/4 the way out first it seems like it is alot smoother. Could be just a worm original clutch? Shifts fine up and down and believe to be a 50k original mile truck.Runs great and there 3 on the tree is solidest tightest I have ever drove literally. No slop whatsoever, feels like I would imagine a new one would on the column. Just bought it and before rebuilding carb I was like having to rev the piss out of it taking off and finess the clutch like a lean jetted old two stroje bike or something! Its gotten way better but still jerky/shaky getting into firat from a full stop.
74 f100 clutch is a little funny
- sargentrs
Re: 74 f100 clutch is a little funny
Sounds like it's time for a clutch and throwout bearing replacement. Have the flywheel resurfaced while the tranny's out.
So I believe I will be replacing the clutch.
Anyhow to links or vids . I have a chilton so theres that but who doesnt like seeing pictures of something they've never done before?
If it shifts fine and your only complaint is a shaky take-off, check out the obvious and easy first. Check the rubber on the driver's side motor mount. A broken mount acts just like a warped flywheel/ clutch plate. Also check all other mounts like transmission and carrier bearing. Any one of geese could produce the same symptoms
- MadMike
Yup.Mach428 wrote:If it shifts fine and your only complaint is a shaky take-off, check out the obvious and easy first. Check the rubber on the driver's side motor mount. A broken mount acts just like a warped flywheel/ clutch plate. Also check all other mounts like transmission and carrier bearing. Any one of geese could produce the same symptoms
Mechanical linkage will be greatly affected by busted engine mounts. You are chasing after the linkage with your pedal but the torque lifting the engine will make you chase after the correct pedal input.
-Michael
