Front Shocks
thatoneguy
Front Shocks
Post by thatoneguy »
I am working on cleaning up a '70 F-100 4x4 frame to put my truck onto and I am having a hell of a time finding front shocks for it. I can find rear shocks all day. I can also find front shocks for 2"-4" lift with no problem. Nothing for stock height...does anyone know where I might find some? I have tried all the parts houses I can think of: O'Reilly, Autozone, Pep Boys, Napa, Advance, Rockauto. Or does someone know where I can find tech specs for the stock shocks that I can try to match something that is close?
Aaron V.
1970 Ford F100 4x4 390/4-spd
1973 Ford Maverick 302/C4
1979 Chevrolet C30 Ramp Truck 454/TH-400
1948 Chevrolet 3800 216/4-spd
1995 Jeep Cherokee 4.0/5-spd
2004 Honda Shadow 1100
"While driving yesterday I saw a banana peel in the road and instinctively swerved to avoid it…thanks Mario Kart."
Oldsch
Re: Front Shocks
Post by Oldsch »
Listed on eBay but who knows???
https://www.ebay.com/itm/NOS-1967-1976- ... SwvOdZl2-e
Discontinued Gabriel but specs are there....
http://gabriel.com/product-search/light ... tnum=82033
To decipher Gabriel mounting codes....
http://gabriel.com/products/docs/Gabrie ... ct2012.pdf
Probably best bet is to find a Monroe that is close based on length and mounting....
http://www.shockwarehouse.com/news/pdf/ ... engths.pdf
Busboy
Re: Front Shocks
Post by Busboy »
I had to buy the ones listed on E-bay. Thanks.
1967 F-100 4x4 custom cab.
Fordzert
Re: Front Shocks
Post by Fordzert »
The stock shocks on eBay?
Busboy
Re: Front Shocks
Post by Busboy »
Yeah, they were about as much as what I paid for the new Monroes for the rear. These were the only ones I could find.
JoshT
Re: Front Shocks
Post by JoshT »
Well... ****
This is one aspect of putting the F-100 back on the road that I didn't consider. There really aren't any shocks listed for front shock replacement on a 4wd F-100 are there. I've been digging for the last few hours and come up with zilch when looking for this application. Next time I'm over there working on it I'll have to get the P/N off the shocks installed and what I can find from that.
Based on the Gabriel shock specs listed below (from the link above) I have maybe found an option, but it's not quite a match and not sure how it would work.
Shock Extended Length: 18.79 in.
Shock Collapsed Length: 12.03 in.
Length of Stroke: 6.76 in
Found Bilstein 5125 custom application shock (P/N 33-062518) that looks pretty close, but not sure how valving would compare.
Shock Extended Length: 18.50 in
Length of Stroke: 6.63 in
That particular Bilstein shock is listed being for 59-75 Jeep CJ5 and 60-82 Toyota Land Cruiser, searching those may reveal some more options. Gotta stop searching for now and get some sleep. In the coming weeks/months I will be doing some more research and maybe call some manufacturers to see if they can recommend anything. If I find out anything I'll try to remember to post what I find.
rbmead
Re: Front Shocks
Post by rbmead »
Good info.
I am in the same boat. I need all 4 for my 72' 4x4
1972 Ford F100 SWB 4x4
thatoneguy
Re: Front Shocks
I ended up with Skyjacker H7012 for the front, they are not exact but appear to be close. We'll see how it does when I get it on the road. Had to order different bushings (Skyjacker ES34) so it would fit the 3/4" top mount.
Aaron V.
rbmead
Re: Front Shocks
Post by rbmead »
Have you had a chance to road test the shocks?
Busboy
Re: Front Shocks
Post by Busboy »
If your asking me no i havent. My truck is at least 6 months away from moving under its own power.
