Hello from Alaska
A place for new members to introduce themselves
RustedHistory
Hello from Alaska
Post by RustedHistory »
Hello everyone, my name is Austin. I am a 17 year old gearhead in Alaska, I own two 1971 Ford F250 Highboys. I've been using this website since 2015 when I bought my first '71. I bought the red Ford from a junkyard in 2015. It originally came off of a farm owned by a guy that abused everything he owned. It had been sitting since 1984. Originally a 300 inline six truck, but someone put a 360 in it somewhere along the line. I was pretty clueless about mechanics then, but I was up for the challenge. I worked on the truck all summer, going by this website, manuals, etc.. for help along the way. The truck needed a lot, I replaced the common parts such as points, rotor, cap, plug wires, etc. I ended up putting a whole new wiring harness in it out of a parts truck from the junkyard as the original was messed with and had wires twisted together with a piece of tape over it.. After a year of adding new and original parts to the truck, I got it running for the first time in over 30 years in 2016. The 360 purred, no issues at all with it. I got the original brakes pumped up again, put driveshafts in it, and drove it that whole summer around the gravel roads. That winter, I parked it for the winter and lost my input shaft seal. The spring of 2017 I pulled the transmission on my own, leaving the stick in it (I hate those NP435 spring loaded retainers.) I cleaned the transmission all up, replaced all gaskets and seals, and repainted it. The truck is close to being road ready now, I just did front wheel bearings last week on it, one drum was about to fall off because the spindle nuts came loose. Now, onto the green '71 F250. I traded a 1992 Dodge Dakota for the Ford in the summer of 2017. The truck was wrecked in 1991, and then was used to run a sawmill, the frame was shortened, and a long two piece driveshaft came off the transfer case to run the sawmill. It had a trailer axle on the back, they were driving it around on the front axle. I got the truck home, had it running the next day after some basic wiring to the ignition. It also has a strong 360 and an NP435 4-Speed. I cut a 4.10 geared limited slip rear axle out of an F100 at the junkyard and put it under my green Ford. I was lucky enough to find the highboy lift blocks, and I had to make my own U-Bolts out of several short ones. I then build a 10 ft. boom on the back of it with a chainhoist for a yard truck. I use it constantly, it's super handy. Check out some pictures below of both my trucks. Thanks for reading, I'm glad I finally got around to making an account on here.
Re: Hello from Alaska
:wel:
Very impressive young man!
Especially creative on the green one. :wink:
Did either or both of them have PS or PB, (being 71' gave them both a better chance of doing so)?
1970FordTK
Post by 1970FordTK »
Way to go, nice 4x4s and welcome from North Carolina. :thup:
RustedHistory
Thank you! Both are manual steering. The green one has boosted brakes, but I only got the fronts working since it's just a yard truck :lol:.
lennyp
Post by lennyp »
:wel: from Massachusetts.
popeyes71
Post by popeyes71 »
:wel: from California! Glad to hear the website was so useful to you and its great to see your to Highboys! Hope to see more of them. :fr:
-Popeye-
1971 F-250 4x4 Highboy
crazyhorse
Post by crazyhorse »
Mr Austin, :wel: to the best site period. :fr:
Hope :pray: you like it here. :fr:
Pull up a chair and stay awhile. :fr:
Congratulations, you have accomplished quite a lot.
hdman90
Post by hdman90 »
:wel: from Pennsylvania! Very impressive work, and hope to do some similar things here in the near future!
RustedHistory
Thank you! I'll get some more pictures together and post them here.
Fordzert
Post by Fordzert »
:wel: Nice trucks you have there
