Custom weld in tail light/turn signal bezel
Private parties only. No eBay/Craigslist listings.
luke-ao
Post by luke-ao »
I did a small run of these but only need one (for a custom Harley brake light) so there's 6 extra. I typically weld them in my bumper after shaving the factory tail lights. These are designed for Harley turn signal lenses which are about $2 each (new) on ebay. I normally make the housing from exhaust pipe and use off the shelf bulb sockets. I'm only selling the lens bezel, CNC machined from 1/4" steel and are threaded to mount your lens.
(All I had was a busted up lens for the picture)
The bezel diameter is 3.65"
Lens diameter is 3.25"
I'll sell them by the pair for $35 plus shipping or all 6 for $100 and free shipping.
Send me a private message if you're interested.
luke-ao
Re: Custom weld in tail light/turn signal bezel
Post by luke-ao »
No fab guys here??
PRICE DROP:
I'll go $75 shipped for all six.
luke-ao
Post by luke-ao »
It might be the wrong forum for these types of fab parts but here is a fender I did a few days ago. These lights are perfect for bumper inserts if you shave the factory taillights (front or rear) you could also put them in flairside fenders, lots of possibilities.
Simple 3-1/2" hole cut with a hole saw.
Assembly tacked in.
Welds ground down ready for body work.
luke-ao
Post by luke-ao »
Body work and primed
