Seat Belt retractor cover
Ron_Hall
Post by Ron_Hall »
Hi guys... anyone know how I can get the cover off without breaking it? :?
Thanks
Ron
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
Busboy
Re: Seat Belt retractor cover
Post by Busboy »
If I remember correctly there are a couple of "nubs" that are on the lower edge. I would heat it with a heat gun assuming it's not already hot as hell where you're at and then gently pry up and out on the housing.
1967 F-100 4x4 custom cab.
Ron_Hall
Post by Ron_Hall »
Busboy wrote:If I remember correctly there are a couple of "nubs" that are on the lower edge. I would heat it with a heat gun assuming it's not already hot as hell where you're at and then gently pry up and out on the housing.
Thanks Busboy, I'll give it a try.
Ron
One owner...
