1972 bench seat
Big bird
1972 bench seat
Post by Big bird »
Have a '72 Ranger XLT Camper Special. Took seat out to recover. Foam is damaged. Want to replace. Found bench seat from a '66. Will foam from '66 fit my bench or is it wrong size?
Re: 1972 bench seat
Post by basketcase0302 »
"Big bird"]Have a '72 Ranger XLT Camper Special. Took seat out to recover. Foam is damaged. Want to replace. Found bench seat from a '66. Will foam from '66 fit my bench or is it wrong size?
It will not fit to my knowledge.
Much easier to upgrade to a newer, (not older) bench (dent era 73-79 uses same bolt holes) which also has better springs and much...more comfortable as the designs gave them with time.
Here's the tutorial on the seats that will bolt right up. :thup:
http://www.fordification.com/tech/seats.htm
Big bird
Re: 1972 bench seat
Post by Big bird »
Thank you. Thats a big help!
dave1972
Re: 1972 bench seat
Post by dave1972 »
Best thing u ever did was get a seat out of a 95 f350 and have it finished at the local upholstery shop in vintage threads. Drill out the rivets and it will bolt right up to your seat tracks.
