Columns Galore
Tell us your good and/or bad experiences
FLASH 1
Columns Galore
Post by FLASH 1 »
pulled a column out of a truck today and found their sticker on the column, well this very nice 1969 short bed out of LA was wrecked in the front and then totaled it and here is what I found, THESE IDIOTS @ Columns Galore installed at the bottom 2 lower bearings and 2 lower bearing sleeves in the same column in which was causing shifting issues + might have caused some steering issues which I believe caused this truck to wreck, When I took the column out and tested to shift popped 1 bearing out and 1 bearing jammed inside the bottom of column.. Anyway after seeing this I would stay away from these idiots that called themselves them professional column builders and not knowing how many more they did this to
Tom, where Ford Trucks Rule
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
1997 F-450 7.3 with 85,000 original miles
2006 F-150 Crew Cab
2008 F-650 Crew Cab Roll Back 6.7 Cummins
2020 Flat Top Peterbilt Roll Back PX-7 Engine
and 2 cars 1968 XLT and 2017 Mustang
Re: Columns Galore
Thanks for the heads up!
Ohiotinkerer
Re: Columns Galore
Post by Ohiotinkerer »
Just seeing their name makes me not want to buy anything from them.... :roll:
1997 Honda CBR 900RR
FLASH 1
Re: Columns Galore
Post by FLASH 1 »
I did get a phone call from them and denied anything I said and more or less put the blame on the customer saying that he painted the column and put their sticker on the column and put extra bearings and bearing sleeves in it, so just passing the buck,
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
2006 F-150 Crew Cab
