Hi all.
I have a 68 RV (see short video) that does not have a key or the cylinder.
https://youtu.be/NNO86CBXOss
To bypass the ignition, I ran a wire from positive on the ignition coil to the positive battery.
The truck is filled with gas. I add some gas to carb and starts and then dies. I suspect a deficient fuel pump as well. There is spark getting to distributor cap.
Question - Is there a better way to hot wire truck? Is the way I’m doing it okay?
Thanks.
Need Help- Start Truck No Key
- socalcraigster
1967 Flareside Shortbed Crew
1969 390 Ranger Long Bed
- basketcase0302
Re: Need Help- Start Truck No Key
Does it still have the points in it? If so you'll fry the points in a short time running straight 12 volts to the coil. The "resistance wiring" coming off of the ignition switch drops the voltage to 9-10 volts for points longevity."socalcraigster" Hi all.
Thanks.
Best to "hot wire it at the ignition switch harness just as your trying to do, (using the same procedure).
Manual or electric fuel pump?
I disagree. You can do this for a short period of time, enough to drive it a short distance. The resister wire does drop votage to 9 volts but that's little difference from 12 volt. Besides, points are cheap.
The way you are hot-wiring is correct, again for a short distance. It sounds like you have more of a fuel issue than ignition. Try putting some gas in a spray bottle and gently spray fuel in the carbureatir after it starts. It should stay running long enough to prove your hot-wire theory.
- sargentrs
You can buy an add on resistor wire from your local parts store. A little expensive but can save your points.
