Axle Degree Shims-Where To Get
RangerRat
Post by RangerRat »
I'm looking for a pair of rear axle degree shims for my 72 F100. My springs measure 2 1/4 wide. All the shims I find are either 2.0, 2.5 or 3 inches wide. Anyone know where to get the correct width shims for our trucks?
RangerRat
Re: Axle Degree Shims-Where To Get
Post by RangerRat »
Also do you have to install a longer bolt in the spring pack?
DuckRyder
Post by DuckRyder »
You might call Eaton Detroit Spring and/or Landrum Spring (I’d start with Eaton personally)
If you’re only adjusting the pinion angle you should not need longer bolts.
Summit carries a large selection. https://www.summitracing.com/search/par ... &tw=pinion angle&sw=Pinion Angle Shims
RangerRat
Post by RangerRat »
I ordered a set 2.5 inches wide, 4 degree. I hope that will be enough to get the pinion angle corrected. I'll take an 1/8 inch off each side to fit the spring width. Have to wait and see about the longer bolt. I'm afraid It will have to be longer with a spacer on the bottom to go all the way through the shim and spring perch. The challenge right now is gonna be getting the nuts loose on the u bolts. Probably gonna take some heat
TxFireman1972
Post by TxFireman1972 »
RangerRat wrote: Mon Nov 18, 2019 8:36 pm I ordered a set 2.5 inches wide, 4 degree. I hope that will be enough to get the pinion angle corrected. I'll take an 1/8 inch off each side to fit the spring width. Have to wait and see about the longer bolt. I'm afraid It will have to be longer with a spacer on the bottom to go all the way through the shim and spring perch. The challenge right now is gonna be getting the nuts loose on the u bolts. Probably gonna take some heat
I know it’s an old post but did the 2.5” wide shims work?
