What Components Do I Change?
Cal2121
Post by Cal2121 »
I have a 68 F-250 CS. I have a recently rebuilt (by Redhead Steering) steering box and new rag joint, but I'd like the steering to be a little "tighter" if possible. It drives fine now, but I'd like it a little better if possible. I believe all of the other components are original. What other components should I change to tighten up the steering? I'd like to make a list and get to work on that.
TIA
jamesdfo
Re: What Components Do I Change?
Post by jamesdfo »
I beam pivot bushings, Radius arm bushings will make a difference, kingpins should at least be checked for play..........
Cal2121
Post by Cal2121 »
Thanks you!
