I Beam help
I Beam help
I'm right in the middle of doing my King pins. I pulled the I beams and spindles off and brought them to the machine shop for the god forsaking "pressing" process. I failed to mark them right and left. Is there a way to tell which side is which? Does it make a difference during install?
re: I Beam help
I haven't gotten that far yet... Anyone know how to tell?
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
re: I Beam help
Well, they'll only fit one way, but just to make it easier on you....look at the casting numbers on the I-beam. Depending on the year and model, they'll look something like this:
See where's there's a number 8 and a number 9 right after the first 4-digit letter/number set? Number 8 goes on the right and number 9 goes on the left.
- 68F250
re: I Beam help
The left and right I-beams have unique numbers, don't know what year yours is but follow this thread for some numbers.
http://fordification.com/forum/viewtopi ... c&&start=0
Barry
- 68F250
re: I Beam help
Sheesh too slow again!
Barry
re: I Beam help
Thanks for the wonderful information. Haste makes waste. I have to tear it back apart in the morning. I knew it looked wrong. son of a ******.
re: I Beam help
But just think how much fun you are having... that and the quality time you are spending with your truck.
Patrick
Chevrolet
re: I Beam help
Allright fellas. dirty deed is done. Swapped the I beams and I'm not sure if because I did it twice but, they went together a whole lot easier this time. You guys saved me alot of pissing and moaning. Thank you. Hopefully test drive it this afternoon.
- flyboy2610
re: I Beam help
I believe the spindles on an F100 are the same right and left.
The F250's are different as the have the sterring knuckle cast into them.
Red Green
you'd better be right.
Red Green
