4x2 cab vs 4x4 cab.
No tech discussion, please
Jsupreme
4x2 cab vs 4x4 cab.
Post by Jsupreme »
I have a 72 4x4 cab that is pretty rusty. I also have access to a 72 4x2 cab that is straight and rust free. What are the differences? Is the transmission hump cover the only thing needs to be swapped over, or is there more cutting involved?
Thank you
390FE1972
Re: 4x2 cab vs 4x4 cab.
Post by 390FE1972 »
The cabs are the same, there are different holes for the rear cab mounts. Here are a couple quotes in regards to this:
"The spots for both 2wd and 4x4 cab mounts are clearly marked on the bottom of the cab. All you have to do is drill the new holes."
"F-100 2wd and F-250 2wd use the inside frame mounts. All 4x4's and F-350's use the outside cab mounts."
Hope this helps! :thup:
Jsupreme
Post by Jsupreme »
Awesome!! Thank you,!!!
FLASH 1
Post by FLASH 1 »
WRONG WRONG INFO,, ALL 67/72 F/100/250/350 Cabs are the same PERIOD. difference is the center hump. 4x4's and automatic Trucks have removable hump. 67/72 2wd is 34'' frame rail as well as the 67/72 4x4 trucks 34'' frame rail,, Chassis Did not change till 1973/79 37'' frame rail EXCEPT 73/early 77 4x4 was 34'' rail and then to 37'' , JUST LOOK @ transfer case which will determine on divorce and married case
Tom, where Ford Trucks Rule
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
1997 F-450 7.3 with 85,000 original miles
2006 F-150 Crew Cab
2008 F-650 Crew Cab Roll Back 6.7 Cummins
2020 Flat Top Peterbilt Roll Back PX-7 Engine
and 2 cars 1968 XLT and 2017 Mustang
390FE1972
Post by 390FE1972 »
Jsupreme wrote:I have a 72 4x4 cab that is pretty rusty. I also have access to a 72 4x2 cab that is straight and rust free. What are the differences? Is the transmission hump cover the only thing needs to be swapped over, or is there more cutting involved?
Thank you
Jsupreme indicated that both cabs are from a 1972, and that he was aware of the differences of the transmission humps. There is a slight difference in 1967 to mid 1971 cabs in regards to the seat belt anchor for the 3 pt shoulder belts, see page 1 at the bottom of the page: http://www.fordification.com/tech/67-72ID_01.htm
Here is a thread that shows the difference in the cab mounts on a F250 4X4 and a F100 4X2 and F250 4X2, and F100 4X4:
https://www.fordification.com/forum/vie ... =5&t=24472
Here is the diagram that shows the F250 4X4 cab mounts:
http://www.fordification.com/tech/image ... unts02.jpg
Here is a diagram of the F100 4X4 with the back cab mounts on the frame crossmember:
http://www.fordification.com/tech/image ... _frame.jpg
Here is another diagram showing the F100 4X2, F100 4X4, and the F250 4X2 with the frame crossmember cab mounting location:
http://www.fordification.com/tech/image ... mounts.jpg
Here is some info in regards to putting a bumpside cab and bed on a dentside chassis:
http://www.fordification.com/tech/chass ... arison.htm
about halfway down the page under DOING A BODY SWAP, it has this to say about putting a bumpside cab on a dentside chassis:
"Mounting the cab and front sheetmetal is a bolt-on affair...there were no changes done to the front part of the frame to affect that. However, keep in mind that the rear cab mounts on all 2WD and F100 4WD trucks are part of the frame crossmember, whereas F250/F350 4WD trucks have a bracket on the outside of the frame. To mount a 2WD cab onto a F250/F350 4WD chassis you'll need to drill new holes in the cab in the areas shown in Fig. 7 (picture coming soon)."
FYI
FLASH 1
Post by FLASH 1 »
did not know that , most likely did not pay attention when we took of the 4x4 cabs off on the 4x4 f-250 trucks
1956 Big Window
1964 F-750 Flat Bed
1965 M-100 Mercury
1966 M-350 Mercury
1966 F350 Wrecker
1972 F-350 Crew Cab
2006 F-150 Crew Cab
cstoyer
Post by cstoyer »
Jsupreme
Depending on how original you are going the seat belt shoulder mount location moved from the back wall of the cab to the side mid 71. Also the fuel tank mounts different in the 67-69 vs 70-72 with 3 bolts vs 5 and of course the obvious climate control change for 68 through 72 vs the 67 only.
CStoyer
68 F250 4x4
Jsupreme
Post by Jsupreme »
cstoyer wrote:Jsupreme
CStoyer
I have a lead on a 72 2x4 cab. So trying to stay 70-72. Thank you for the help fellas.
