'68 F250 Front Disc Brake Help
tg11350
Post by tg11350 »
I am totally rebuilding the brakes on my '68 F250 CS. They are power assist with disc on the front and heavy duty drum on the back. I ordered and received the hardware kit for the front. Before I tore everything apart I took a bunch of pics so I would know how to put it back together but ALAS I believe both wheels were put back together without all the parts installed from the kit. I've scoured the internet for pics so I can reassemble everything as prescribed but I can't find any. Can anyone provide any internet links so I can finish this job correctly? I would be most appreciative.
Thanks in advance,
Tony
390FE1972
Re: '68 F250 Front Disc Brake Help
Post by 390FE1972 »
I don't have any pictures of the 1968 F250 disc brakes, but here is the schematic in case you hadn't seen it. There are a number of pictures for the 1972 set up that can be provided, but they are a little different set up from the 1968 disc brakes. Hopefully someone will be able to provide you some pictures, and internet links. http://www.fordification.com/tech/image ... scF250.jpg
Regards :thup:
