Oil for a rebuilt 390
cougswan
Post by cougswan »
I just had my 1970 3/4 ton’s 390 engine completely rebuilt. I have driven a few hundred miles and I am looking to change the oil. What kind of oil should I use?
Thanks!
Alex
1970 Ford F250 390
pcmdub
Re: Oil for a rebuilt 390
Post by pcmdub »
Ughhh. Such a huge debate.
I use Mobil 1 15-50w. https://www.walmart.com/ip/Mobil-1-Adva ... ected=true
It contains the ZDDP additive that flat tappet cams require and is trustworthy from Mobil 1. Better yet, it is cheap from Walmart.
However, I have also tried Lucas Oil https://www.walmart.com/ip/Lucas-Oil-Ho ... t/49692050
Either way, they are both great. Just be sure you have zinc in there and try to avoid additives to oil because some don't play nice together.
HDxLoki
Post by HDxLoki »
Since it’s a rebuilt motor I wouldn’t run anything thicker than a 10w-30 because of the tighter bearing tolerances. The topic of oil is a tricky one cause everyone has a different opinion. Bottom line I would run an oil with ZDDP/Zinc. Good choices are Vavoline VR1, PennGrade, or Schaeffer's. Personally I run schaeffer's in my Ram 2500 w/ 6.7l CTD and plan on running their 10w-30 when I finish my 390 rebuild.
1972 F250 Ranger XLT Camper Special 390ci Bought Brand new in 1972 and passed down from my Grandpa after he passed
RIP Paul & Von
