Amp gauge to volt gauge
BigAl47
Post by BigAl47 »
I have a 1972 f250 360 sport custom. Would like to change my amp gauge to a volt gauge. Does anyone have pictures showing how to do this. My instrument panel has the printed circuit. Could use some info
Also going to a 100 amp alternator :fr:
Thanks in advance
390FE1972
Re: Amp gauge to volt gauge
Post by 390FE1972 »
Here are a couple threads that discuss this, according to this, your instrument cluster and printed circuit boards are different as well as your wiring harnesses. The first thread talks about hooking up aftermarket amp gauge etc. Hope this helps!
http://www.fordification.com/forum/view ... =8&t=74108
http://www.fordification.com/forum/view ... =8&t=77891
Regards :drive:
cash667
Post by cash667 »
You can‘t use the wiring from the ammeter on the voltmeter.
A Voltmeter needs basically 3 wires:
12v IGN
Ground
12V for Lamp
You have a 12V ignition source on the input of your IPVR on the Cluster, in the older models this is a black/green stripe wire.
Ground is easy.
12V for lamp should be picked up from the cluster lamp feed. It should be a blue/red stripe wire in the harness. I think you cant pick it up directly on the cluster because it‘s all printed circuit and the cluster lamps are directly contacting the printed circuit.
Cheers
Chris
1968 Mercury Cougar 302
1968 Ford F250 Camper Special 429
BigAl47
Post by BigAl47 »
I want to install a volt gauge from rocketman so it match’s all my gauges. So what do you need to do to the printed circuit board to disconnect amp gauge wiring and convert to volt meter.
Thank you :fr:
390FE1972
Post by 390FE1972 »
Here is an Auto Restomod youtube that sounds like just what you need to do the conversion without changing out everything:
https://youtu.be/rZns7fGH9sI
Hope this helps! :thup:
BigAl47
Post by BigAl47 »
Thank you :fr:
