Replacement radiator
Hi again.
The truck's engine is back in after being rebuilt by Jasper. Purrs like a kitten.
Radiator is leaking from a seam.
We tried all the local parts places, and also tried LMC truck.
No luck.
Any of y'all got a for-sale radiator for a '67 F100 2WD Auto 352?
Or know where to go to find one?
Thanks a lot
No luck.
Thanks a lot
1967 F100 352 Auto LWB 2WD Camper Special
- jimmy828
Re: Replacement radiator
Are you wanting to use the OEM style radiator? Several vendors have a look a-like but it's made from aluminum not copper. I used a Champion 3 row myself and it fit just like the old OEM rad i took out.
Thank you. I think I’d prefer an OEM one but I’d more prefer to get it on the road
Any radiator shops in your area ?
they might be able to solder it ,and run a lower pressure cap.
- basketcase0302
That would be a red flag for me, (if the "new" rebuilt engine is running hotter the pressure has gone up causing that leak)!="Old+Blue"Hi again.
No luck.
Thanks a lot
Make sure you have an accurate mechanical temperature gauge, (it's the most important thing you can do for that new engine besides a mechanical oil pressure gauge). Way...too much money invested into a rebuild for any kind of issue to shorten it's life.
And like CEP said if you're anywhere near a decent sized city you'll find a radiator shop that should be able to repair your OEM, (or even quote you on a complete flush/repair job with a warranty.
That's a good point that I hadn't thought of, thank you.
I drove the truck only maybe 15 miles before the engine removal so I really don't know if it was running hot before.
It _was_ already leaking when I got it.
Is there a reason not simply add some Bar's Leaks Stop Leak, as a stop-gap while I look for a radiator shop?
As far as I know, the closest shop is about a 90 minute drive...
- basketcase0302
Maybe get a few more opinions on using bars leak, (I've used some extremes to stop leaks)."Old+Blue"That's a good point that I hadn't thought of, thank you.
Picture being 10 miles out in the swamp and a radiator leak develops and all you have is your food for a hunting camp, (egg whites and or/black pepper more than once).
And I've used Bars Leak, (against advice of some folks it "clogs" internals of an engine-not real good for it.
But if it were my brand new engine...I'd weight on the side of caution.
I tried the best rated radiator shop, and a few others. No luck. The best I could get was a minimum of $550, _if_ it could actually be rebuilt. Couldn’t find a replacement in stock anywhere. So I’ve ordered one from US Radiator. Pricey but I can get it on the road.
Thanks for all the help.
You could have gotten an aluminum Champion off EBay for half that shipped.
Well heck, I never even thought of looking on eBay. I will next time!
Appreciate the help.
