T5 transmission swap
Blueford1
Post by Blueford1 »
Hey all,
Looking at a Borg warner t5 out of a 1982 chevy s10. Would this work as a swap for my NP 435?
Thanks.
1970 F100/302 5.0/4 speed/ Ford9inch 3.70
Re: T5 transmission swap
="Blueford1"Hey all,
Thanks.
Two things for sure I know is that you'd have to run a transmission adapter plate and flywheel, and you'd have to adapt/marry the "wet clutch" to the truck.
Look for the same T-5 in a Fox body Stang' would make it much easier. :2cents:
M-100
Post by M-100 »
You can use an adapter that goes between the bell house and transmission much simpler and cost effective. I posted a little more info on your other post in the engine section
