PLASTIC PINS IN GRILLE?
COOP3
Post by COOP3 »
On the Grille Shell, there are 3 plastic inserts or pins in the headlight areas. They are located behind the headlight buckets. First, what is their function? Second, does anyone sell replacements. I can't find them shown anywhere, they don't even show in the MPAC? The grille is 71 F250.
1971 F250, Camper Special, 360-2V, Manual Steering, 4spd
Jbarnes79
Re: PLASTIC PINS IN GRILLE?
Post by Jbarnes79 »
There are 4 "Pin" style inserts that attach the chrome headlight door to the Grille.
https://www.dennis-carpenter.com/trucks ... grill-nuts
Since you mentioned there are only 3 behind the bucket, I'm wondering if these headlight adjustment screw clips are what you're referring too instead.
https://www.dennis-carpenter.com/trucks ... -screw--nu
http://fordification.com/forum/viewtopic.php?t=67810
1969 F250 4x4
1969 F250 Crew cab (Sold)
1972 F250
1969 & 1970 Mustang
COOP3
Post by COOP3 »
Those are not the parts. They look like smooth round buttons that come with the grille shell. In the following link you see them faintly when you select the headlight photo. They are located around the headlight cutout. I need to learn how to post photos & links. A friend of mine told me when you adjust the headlamps these allow the bucket to pivot easier and stay stationary.
https://www.dennis-carpenter.com/trucks ... alum-shell
Jbarnes79
Post by Jbarnes79 »
I wonder if these are what you're looking for in this hardware kit.
https://www.dennis-carpenter.com/trucks ... rdware-kit
1969 F250 4x4
1972 F250
1969 & 1970 Mustang
Jbarnes79
Post by Jbarnes79 »
In order to post photos in a post you'll need to load them into a photo sharing website. I use Flickr but there are several others.
Once you've uploaded them to an online server you will need the direct link to the photo. Once you have the direct link, you just need to add a short code before and after the link. I hope that makes sense.
There is an explanation here.
https://www.bbcode.org/posting-images-w ... .php?id=10
1969 F250 4x4
1972 F250
1969 & 1970 Mustang
