1967 f250 2wd brake size
sheehyct
Post by sheehyct »
Hey guys I'm sure this is somewhere on here but for the life of me I can not find it. I've read conflicting information online whether the 2wd used 2 inch or the 2.5 inch for the drum brakes. I'm getting ready to do mine (front and rear) so any helpful links or info you have would be greatly appreciated thanks!
Ren
Re: 1967 f250 2wd brake size
Post by Ren »
Take off a front wheel and take a visual note of the overall size of the drum. Take off a rear wheel and compare the front and rear drum visually.
If the rear drum is massive and looks alot different compared to the front drum, it's a 2.5" brake.
The 2" drum can be removed with a mallet. The 2.5" drum will require you to remove the axles from the rear end.
There are lotsa' Dana 60 brake youtube videos on this subject to help.
