Timing cam gear spacer
Just replaced my old timing chains with new Cloyes gears/ chain, and noticed the cam gear sits a couple mm closer to the block than the crank gear. I know I've seen people mention a spacer that is sometimes needed behind the thrust plate, but I can't find it in any part diagrams. Anyone have an idea what/where I'm missing something?
Martin
1972 2WD F-250
1994 Suzuki Savage 650
2014 H-D Sportster 1200
1972 2WD F-250
Re: Timing cam gear spacer
According to an article on diyford.com/camshafts they explain that early sbf (pre 65 had two piece thrust plates and different thickness plates were available. It depends on camshaft end play as to what is needed.
68 Ranger. 302 Clevor w/ 3 on tree, soon to have front disc brakes.
