68/69 Aux fuel tank filler hose
Vwbuggin69
Post by Vwbuggin69 »
So I removed my aux tank to replace the rubber lines because the vent hose was cracked. Come to find out no one makes the fuel filler hose or I cannot find it. What have y’all done to get the proper length hose? I’m trying to bring back the aux tank so I can use it and not have to fill up every 15 minutes (joke). Thanks
1969 VW Beetle (Daily)
1968 F-250 (Walter)
Weber grill hoarder
ISS Protection Team
Re: 68/69 Aux fuel tank filler hose
=Vwbuggin69
I'm pretty sure that Keith our founding member and administrator is currently working on his aux tank too as I write this.
Shoot over to the Fordification fakebook group and look for his post there.
I never had the aux tank but am guessing the regular gas filler hose wont' work?
Vwbuggin69
basketcase0302 wrote: Tue May 16, 2023 7:08 am
=Vwbuggin69
Thanks for the tip. I posted on his FB post. FIngers crossed he has found a hose I could use.
1968 F-250 (Walter)
Weber grill hoarder
ISS Protection Team
Silverflash
Post by Silverflash »
You might check with LMC Truck because that is where I picked up my set of hoses and "U" shaped sheetmetal shield where it crosses over the frame.
Jbarnes79
Post by Jbarnes79 »
http://fordification.com/forum/viewtopic.php?t=67810
1969 F250 4x4
1969 F250 Crew cab (Sold)
1972 F250
1969 & 1970 Mustang
Mach428
Post by Mach428 »
When I restored my truck, a neighbor of mine worked at Dayco. I measured the size of the hose and bought one from them rated for fuel. It’s been in my truck for 32 years.
youngbodean70F250
Post by youngbodean70F250 »
I had the same problem finding the correct fuel filler hose for my 1968 F250 CS with the under cab aux tank. After looking everywhere, I finally lucked out and found this company (fillernecksupply.com) that made EXACTLY what we all need. It’s a 2 1/4” fuel hose with a 45 degree in the middle, so you can trim off the extra on one of the ends. Exact fit and under $30. I used the original connectors, etc. Hopefully the pics came through.
Part # D225A45X
