Heater Core - keep or get new?
- JWW
I have finally disassembled my heater box. I do not plan to drill out the rivets; I will try to clean the best I can. I would like some advise on the heater core itself. Is there a way to check for leaks at home? Finding a radiator shop these days is hard and a new core is not too expensive. I'm curious what you all have done. Thanks
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
My project: http://www.fordification.com/forum/view ... &sk=t&sd=a
2004 F150 Crew Cab
Re: Heater Core - keep or get new?
In the past, I have just run a garden hose in both directions until it runs clear. If you can't pressure test it how about vacuum? I have no experience with the repops, so no opinion there.
Was your heater full of mice? I have found they will return no matter how much you clean, however painting the inside of the plenum seems to seal their scent so they are not drawn back.
F. Noble, Saskatchewan.
- jzjames
Heater core; mine leaked and I just got a new one. Radiator shop said he didnt recore those.
- JWW
Thanks, luckily no mice. I'll do some cleaning with a hose and see how it ends up.Fraser wrote: ↑Wed Jun 07, 2023 10:59 pm In the past, I have just run a garden hose in both directions until it runs clear. If you can't pressure test it how about vacuum? I have no experience with the repops, so no opinion there.
Makes sense. Hard to find anyone any longer that does this type of work.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
You could use a bicycle inner tube and pressurize it and dunk it in a tub of water to check for leaks.
But I hate doings things twice , if I have it apart I'd probably put a new one in .
- JWW
Thanks, think I’ll get a new one.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
- basketcase0302
Def worth the $58 dollars investment! The rivets really aren't that big of a deal and by going into the box you'll also find it needed some new foam weatherstripping to properly seal air that was by-passing the heater core.
DC is out of them but I bet LMC or my fav NPD has them:
https://www.dennis-carpenter.com/trucks ... wstd-heate
You are working on a vehicle over 50 years old. If you can’t find a radiator shop to recore your original (absolute best option in my opinion because you know it fits) then invest the coin for a new one. Your time is worth more than doing this job more than once.
- JWW
Thanks. I found most everything on LMC. I’ll drill the rivets out since I have it out of the truck.basketcase0302 wrote: ↑Fri Jun 16, 2023 5:15 pm Def worth the $58 dollars investment! The rivets really aren't that big of a deal and by going into the box you'll also find it needed some new foam weatherstripping to properly seal air that was by-passing the heater core.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
- JWW
Agree, thanks. It feels good to refurbish what you can too.Mach428 wrote: ↑Sun Jun 18, 2023 2:32 pm You are working on a vehicle over 50 years old. If you can’t find a radiator shop to recore your original (absolute best option in my opinion because you know it fits) then invest the coin for a new one. Your time is worth more than doing this job more than once.
JWW
2004 F150 Crew Cab
2004 F150 Crew Cab
