January 1969 - December 1969
Bulletin No. 127 - November 21, 1969 [COMPLETE]
(13 articles)
  • Article 1998 - New Special Service Tool Required for Checking Revised 1970 Converter Hub Turbine
    (1970 Vehicles with C-4 Transmission)
  • Article 1999 - New Front Wheel Bearings
    (All 1970 Passenger Cars)
  • Article 2000 - Front Hub Cap Interference with Bearing Dust Cap
    (1970 Ford Passenger Cars with 15 x 5.00 Wheels and Drum Brakes)
  • Article 2001 - Front Wheel Hub bolt Replacement - Supersedes T.S.B. #125, Article 1972
    (All Passenger Cars with Disc Brakes)
  • Article 2002 - 1968-69 Rear Leaf Spring - Bottom Leaf Askew - (Cancels and Supersedes TSB #100, Article 1507, October 18, 1968)
    (1968-69 F-100/250 and F-100 4x4)
  • Article 2003 - Replacement of Standard Front Shock Absorbers
    (1968/69 F-100/250 Trucks With Standard Shock Absorbers)
  • Article 2004 - Dana Rear Axle Housing Alignment Checking Procedure
    (F-100/350, P-350/400, P-3500/4000 and E-300 - 1965-1970)
  • Article 2005 - Ford Rear Axle Housing Alignment Checking Procedure
    (F-100, E-100/200, Bronco - 1969-70)
  • Article 2006 - Clutch Housing - Remove and Install
    (Fairlane, Montego 429 C.I.D. 8 Cylinder 4 Speed Standard Transmission)
  • Article 2007 - Delayed Reverse Engagement or Erratic Kickdowns
    (All 1970 C-4 Automatic Transmissions except Falcon)
  • Article 2008 - Power Loss During High Altitude Operation
    (1968-69 F-100/250 With 360/390 CID Engine)
  • Article 2009 - Improper Park Position of L.H. Windshield Wiper Arm Assembly
    (1970 Fairlane)
  • Article 2010 - Loose Seat Belt Retractor Cover and Partially Installed Plug Button
    (All 1970 Models)
