January 1970 - December 1970
Bulletin No. 140 - May 22, 1970
(21 articles)
  • Article 2318 - Rear Suspension Bottoming - (Fairlane - All 4 Dr. Sedans and 4 Dr. Hardtops - 1970)
  • Article 2319 - Transmission Locks Up n Low Gear When Shifting From Reverse Gear - (All Medium, Heavy and Extra Heavy "C" Trucks with Clark 280 Series - 1968-1970 Models)
  • Article 2320 - Anti-freeze - Protection Level - (All Carlines - 1970)
  • Article 2321 - Engine - Oil Baffle Tray Bolts - (Mustangs Equipped with Boss 302 Engines - 1969-1970 Models)
  • Article 2322 - Engine - Oil Pan Fill Level - Revised - (1969-70 Mustang 428 CJ, 428 SCJ, Boss 302; 1969 Fairlane 428 CJ, 428 SCJ; 1970 Fairlane 429 CJ, 429 SCJ)
  • Article 2323 - Push Rods - Oversize/Undersize - (351C Engines - 1970)
  • Article 2324 - Engine Identification - Cobra Jet Series - (1970 429 CJ/SCJ, 428 CJ/SCJ)
  • Article 2325 - Hydraulic Tappet - Adjustment - (1970 429 CJ)
  • Article 2326 - Clutch Pilot Bearing - New - (Cortina - All Engines - All Years)
  • Article 2327 - Flywheel to Crankshaft Mounting Bolt Sealant - (All Caterpillar V-8 Diesel Engines)
  • Article 2328 - Crankshaft Damper and Pulley Loosening - (Trucks Equipped with 6-71 Detroit Diesel Engines, Without Power Steering - 1969 and Prior Models)
  • Article 2329 - Rear Engine Mount Looseness - (C-6000-7000-8000 Trucks with Caterpillar V8 Engines - 1969)
  • Article 2330 - Injector Pump Timing Advance Unit Relocation - (Certain Caterpillar V-8 Diesel Engines)
  • Article 2331 - Ignition Switch & Wiring Connector - Service Program J-49 - (All Passenger Cars - 1969)
  • Article 2332 - Front Seat Back Angle - (Fairlane, Models 54-57-71 - 1970)
  • Article 2333 - Door Window - Blow Out Clip Replacement - (Ford and Thunderbird - 1970)
  • Article 2334- Water Leaks into Station Wagon Wheel Wells - (Ford 1969-1970)
  • Article 2335 - Fiberglass Fractures at Fender Sight Rods - L Series - ("L" Series Trucks - All N-NT-F-FT Series -1970)
  • Article 2336 - Glamour Paint Code "89" Bronze Fire - (Thunderbird - 1970)
  • Article 2337 - L-Series Glove Box - Improved Floor-Mounted - (All "L" Series with R.P.O. Glove Box - 1970)
  • Article 2338 - Sheet Metal Cracking at Lower Rear Corner of Door Opening - ("W" Series Truck - Steel Cab - 1966½-1970)
cron
