January 1970 - December 1970
Bulletin No. 146 - August 7, 1970 [COMPLETE]
(18 articles)
  • Article 2977 - Front Wheel "Shimmy"
    (F, B, N, 500-750 and 6000-7000 With 5,000 Lb. thru 9,000 Lb. Front Axle with Integral Power Steering)
  • Article 2978 - Twin I-Beam Alignment Checking Procedure
    (THIS ARTICLE CANCELS AND SUPERSEDES ARTICLE 1824, BULLETIN 117 AND ARTICLE 1986, BULLETIN 126)
    (F-100-250-350 1965-1971, Econoline 1969-1971)
  • Article 2979 - Automatic Transmission - Reverse Clutch Pressure Plate Rebuilding
    SUPERSEDES ARTICLE 2279 TSB 138)
    All Cars with C-6 - 1970)
  • Article 2980 - Automatic Transmission - C6 - Delayed Drive to Reverse Engagement
    (All with C6 [XPL] - 1968-1970)
  • Article 2981 - Automatic Transmission - C6 - Intermediate Flex Band Failures
    (All with C6 [XPL] Transmission - 1966 thru 1970)
  • Article 2982 - C-6 Automatic Transmission Service
    (F-600 Trucks with 330 HD Engine - 1970½)
  • Article 2983 - Oil Economy - LPG 330, 361, and 391 CID Engines
    (Medium and Heavy Trucks with Production Installed LPG Conversion - 1967-1970 Models)
  • Article 2984 - Accelerator Governor Lever Travel
    (L-Series Trucks Equipped with Caterpillar V-8 Diesel Engines - 1970)
  • Article 2985 - Throttle Linkage Kit - New
    (All C-Series Trucks Equipped with Caterpillar V-8 Diesel Engines)
  • Article 2986 - Lubricating Oil Filter Service Clamp Assembly
    (Trucks Equipped with Detroit Diesel 8V-71 Engines - 1969 and Prior Models)
  • Article 2987 - Engine Detonation
    SUPERSEDES TSB 133, ARTICLE 2135
    (Vehicles Equipped with 429-2V and 429-4V CID Engine [Except 429 CJ and 429 SCJ] - 1970)
  • Article 2988 - Starters - Use of Connector Link on Solenoid Actuated
    THIS ARTICLE CANCELS AND SUPERSEDES ARTICLE 2964, TSB 145
    (All Vehicles with a Solenoid Actuated Starter and a Starter Relay)
  • Article 2989 - Alternator Regulator Road Splash Protection
    (Thunderbird - 1970)
  • Article 2990 - Side Marker Lamp Bulb Socket - Service Replacement
    (All Car Lines - 1970)
  • Article 2991 - Turn Signal Switch part Substitution
    (All Car Lines with Fixed Steering Column - 1970)
  • Article 2992 - Speedometer Pointer Sticking to Zero Stop
    SUPERSEDES TSB ARTICLE 2971
    (Ford, Torino, Econoline, Light Truck - 1970)
  • Article 2993 - Air Conditioning Compressor Seal Leak Diagnosis Procedure
    (All Car Lines Equipped with Air Conditioning)
  • Article 2994 - Ignition Lock Inoperative
    (All 1970 Car Lines)
WEBMASTER'S NOTE: The following note was printed in TSB #147:
PLEASE NOTE: Due to a printer's error, all articles published starting with TSB No. 144 were mis-numbered. This error was a transposition of the digits 2391 to 2931. Thus, the block of numbers 2391 to 2930 were not assigned.
cron
