January 1970 - December 1970
Bulletin No. 149 - September 25, 1970
(34 articles)
  • Article 3052 - Air Exhausts From Brake Foot Control Valve Exhaust Port - (All "L" Series with Air Brakes and a Tractor Package - 1970)
  • Article 3053 - Rear Wheel Spring brake Chamber - Air Filter Maintenance - All Medium, Heavy and Extra Heavy Trucks with Bendix Wedge Rear Brakes and M.G.M. "Shortstop" Spring Brake Chambers - 1970 and Past Model)
  • Article 3054 - Front Axle Contact with Frame Flange at Rubber Bumper - (Econoline 100-200-300 Series - 1969-70)
  • Article 3055 - Clutch Internal Adjustment Revision - (L and W Series Trucks with Spicer 14-Inch 2-Plate Clutch)
  • Article 3056 - Clutch Center Drive Plate Rattle - (heavy and Extra Heavy Truck Equipped with 13- and 14-Inch Two-Plate Clutch and Caterpillar/Ford V8 Diesel Engine)
  • Article 3057 - Standard Transmission Driveshaft "Ring" Sound - (Maverick w/200 CID and Standard Transmission Model RAN-BBL - 1970)
  • Article 3058 - Clogged Fuel Tank Rear Vent Tube - SUPERSEDES ARTICLE 3032, TSB 148 - (Fairlanes without Evaporative Emission System - 1970)
  • Article 3059 - Ignition System Diagnosis Guide - (All Engines)
  • Article 3060 - Air Cleaner - Vacuum Hose to Bi-Metal Sensor Missing - (Ford with 400 CID Engine - 1971)
  • Article 3061 - Air Cleaner - Binding Duct Valves - (All with 351C, 400 and 429 CID Engines - 1971)
  • Article 3062 - Exhaust Pipe Rattle - Muffler to Frame Support Bracket Reinforcements - L Series - (L-Series Diesels with Vertical Exhaust and Muffler Mounted Outboard of Frame)
  • Article 3063 - Radiator Sight Glass Leakage - L Series - (All L Series Trucks - 1970)
  • Article 3064 - Anti-Freeze Concentration - (Medium and Heavy Trucks - All Engines)
  • Article 3065 - Radiator Connector Leakage - New Upper Radiator Hose - (L-LN-LT-LNT-LTS-900 Trucks with Super Duty Engines - 1970)
  • Article 3066 - Spark Plug Gap Specification - (Pinto - 1971)
  • Article 3067 - Parking Lamp Intermittently Inoperative - Light Truck - (F-100-350 - 1970)
  • Article 3068 - Glove Compartment Light Inoperative - (Mustang - 1970)
  • Article 3069 - Radio - Ignition Noise - (Ford with 302 and 351 CID Engines - 1971)
  • Article 3070 - Radio Antenna Lead Too Short - (Ford with AM or AM Radio Tape Player - 1971)
  • Article 3071 - Air Conditioning System - Fresh Air Damper Sticking - (Ford - 1971)
  • Article 3072 - ATC System Inoperative - (Ford Equipped with ATC and Speed Control - 1971)
  • Article 3073 - Air Conditioning System Contamination - (All A/C Equipped Vehicles - 1970-1971)
  • Article 3074 - Refrigerant Leaks at Air Conditioning Service Valves - (All Vehicles Equipped with A/C - 1970-71)
  • Article 3075 - A/C Plenum Door Crank Arm Hangs up on Edge of Defrost Vacuum Motor Opening - (Mustang with Air Conditioning - 1971)
  • Article 3076 - Safety Standard Certification Decal - Service Replacement - (All Cars and Trucks - 1970)
  • Article 3077 - Window Noise Front Door Window Glass - (Thunderbird - Models 65A and B - 1971)
  • Article 3078 - Power Window Master Control Switch Replacement - (Thunderbird - 1971, 1970, 1969 [Built After 3-29-69])
  • Article 3079 - Power Window Motor - Preventing Water Contamination - (All Vehicles Equipped with Power Windows - 1970)
  • Article 3080 - Rearview Mirror Looseness - (All Carlines with Button Type Windshield Mounted Rearview Mirrors)
  • Article 3081 - Luggage Compartment Water Leaks - (Mustang - 1971)
  • Article 3082 - Front Seat Back Pivot Arm Covers Fall Off - (Mustang and Maverick - All Models with Bucket Seats - 1971)
  • Article 3083 - Water Leaks at Quarter Window and Quarter Trim Panel Area - (Mustang Model 65 - 1971)
  • Article 8084 - Bright Metal Drip Moulding Application - (Maverick - 2-Door, 4-Door with Base Accent Group and All Grabber Sport Sedan Models - 1971 Model)
  • Article 3085 - 1971 Pinto Maintenance Time Allowances - (Pinto - 1971)
cron
