January 1970 - December 1970
Bulletin No. 152 - November 13 - 1970
(22 articles)
  • Article 3125 - Vehicle Sag - Left Side - (Cortina - 1969-70)
  • Article 3126 - Rear Suspension Bottoming - (Mustang - 1971)
  • Article 2127 - Automatic Transmission - Shift Lever Rattle - (Mustang - 1971)
  • Article 3128 - C6 Automatic Transmission - High Clutch Piston Spring Set - (All with C6 - 1971)
  • Article 3129 - FMX Automatic Transmission - Front Clutch Failures - (All with FMX - 1968 through 1971)
  • Article 3130 - FMX Automatic Transmission - No Downshift When Cold - (All with FMX - 1970 and 1971)
  • Article 3131 - Servicing Rear Axle Vents - (All Trucks Equipped with Rear Axle Vents - 1970-71)
  • Article 3132 - Engine - Valve Lash - Revised - (429 SCJ - 1970)
  • Article 3133 - Distributor - 400-2V - (Ford -1971)
  • Article 3134 - Back-up Lamp Switch Damage During Transmission Service - (Pinto with 4-Speed Manual Transmission - 1971)
  • Article 3135 - Rework of Truck Tractor wiring to Accommodate Trailers with Common Marker and Tail Lamp Circuit - (All Truck Tractors - 1969-70-71)
  • Article 3136 - Inoperative Radio System - (Ford, Mustang and Thunderbird - 1971)
  • Article 3137 - Radio Antenna Lead-In Cable Routing - (Ford with Fender Mounted Antenna - 1971)
  • Article 3138 - Windshield Wiper Knob Removal - (Ford - 1971)
  • Article 3139 - Air Conditioning Insufficient Cooling or Reduced Air Flow Through Registers - (Pinto with A/C - 1971)
  • Article 3140 - Insufficient A/C Cooling - Control Lever Sticks "Max A/C" Position - (Ford Equipped with A/C - 1971)
  • Article 3141 - Front Seat Cushion - Click and/or Squeak Noise - (Pinto - All Models - 1971)
  • Article 3142 - Front Seat Back Cover Damaged - (Mustang - All Models; Maverick - All Models with RPO Bucket Seats - 1971)
  • Article 3143 - Hood and Luggage Compartment Door Letters Loose - (Ford - 1971)
  • Article 3144 - Instrument Panel Ash Receptacle Difficult to Open - (Pinto - All Models - 1971)
  • Article 3145 - Plastic Ornamentation Heat Damage - (Models Equipped with Plastic Ornamentation - 1971)
  • Article 3146 - Potential Radiator Grille Damage - (Thunderbird - 1970)
cron
