January 1970 - December 1970
Bulletin No. 153 - November 20, 1970
(13 articles)
  • Article 3147 - Exhaust System Boom - (Maverick - 4 Door Models Equipped with 200 CID Engines - 1971)
  • Article 3148 - Squeaking Noise in Steering Column Bearing when Shift Lever is Moved - (Mustang - 1971)
  • Article 3149 - Pinto Engine Tie Down Hooks - (2000cc Engine)
  • Article 3150 - Dieseling - Throttle Solenoid Adjustment - (Pinto - 1600cc - 1971)
  • Article 3151 - Overheating - Engine - (351-C/400-C Engines - 1970-71)
  • Article 3152 - Water Pump Gaskets - Applications - (All 429 CID - 1968-1971)
  • Article 3153 - Use of Low Lead Fuel - (1970 and Prior Model Year Engines)
  • Article 3154 - Cigar Lighter Inoperative - Fuse Blown - (Mustang - 1971)
  • Article 3155 - Fuse Link Burned Out - (Pinto 1971)
  • Article 3156 - Starter Relay Solenoid Switch Relocated to Prevent Interference with te Hood - (Ford - 1971)
  • Article 3157 - Hood Outer Panel Flutter - (All Models - 1971)
  • Article 3158 - Installation of Fender Mounted Antenna - (All Models Equipped with Body Side Mouldings - 1971)
  • Article 3159 - Wheel Splash Guard - (All Models - 1969-70-71)
cron
