January 1970 - December 1970
Bulletin No. 154 - December 4, 1970
(31 articles)
  • Article 3160 - Pinto Shop Manual Revisions - (1971)
  • Article 3161 - Pinto Shop Manual Revisions - (1971)
  • Article 3162 - Disc Brakes - Repair Procedures - (Pinto - 1971)
  • Article 3163 - Front Suspension Upper Arm Bushings Replacement - Arm Removed - (Pinto - 1971)
  • Article 3164 - Ford of Britain Four-Speed Transmission - (Pinto with FOB Transmission - 1971½)
  • Article 3165 - Revised Pinto Clutch Free Play Adjustment - (1971 Pinto)
  • Article 3166 - Automatic Transmission - Lower Control Valve Body Assembly Revision - (1971 Pinto w/C4 Automatic Transmission)
  • Article 3167 - Ford of Germany Four-Speed Transmission Procedure and Specification - (Pinto - 1971)
  • Article 3168 - Automatic Transmission Shift Speed Chart - Revised - (Pinto with C4 Automatic Transmission - 1971)
  • Article 3169 - Automatic Transmission Low-Reverse Band Adjustment Tools Revised - (Pinto with C4 Automatic Transmission - 1971)
  • Article 3170 - Performance Specifications - Revisions - (Pinto - 1971)
  • Article 3171 - 1600cc Engine Specification Revision - (Pinto - 1971)
  • Article 3172 - 2000cc Engine Specification Revision - (Pinto - 1971)
  • Article 3173 - 2000cc Engine Valve Adjustment Revision - (2000cc Pinto Engine)
  • Article 3174 - Autolite Model 1-V Carburetor Adjustments - (Pinto - 1971)
  • Article 3175 - Autolite Model 5200-C 20V Carburetor Adjustments - (Pinto - 1971)
  • Article 3176 - Fuel Pump Specification Revision - (Pinto - 1971)
  • Article 3177 - Air Cleaner Revisions - (Pinto - 1971)
  • Article 3178 - Pinto A/C Removal and Installation and Testing Procedures - (Pinto - 1971)
  • Article 3179 - Rear Seat Trim - (Pinto - 1971)
  • Article 3180 - Moulding Removal Tool - (Pinto - 1971)
  • Article 3181 - Luggage Compartment Door - Model 64B Removing and Installation Procedure - (Pinto - 1971)
  • Article 3182 - Door Trim Panel - (Pinto - 1971)
  • Article 3183 - Quarter Trim Panel - (Pinto - 1971)
  • Article 3184 - Floor Console - (Pinto - 1971)
  • Article 3185 - Headlining - (Pinto - 1971)
  • Article 3186 - Instrument Panel Pad - (Pinto - 1971)
  • Article 3187 - Rear Bumper - (Pinto - 1971)
  • Article 3188 - Front Fender - (Pinto - 1971)
  • Article 3189 - Grille - (Pinto - 1971)
  • Article 3190 - Engine Oil Dipsticks - (Pinto - 1971)
cron
