January 1970 - December 1970
Bulletin No. 155 - December 11, 1970
(25 articles)
  • Article 3191 - Service Information - (All Models - 1971)
  • Article 3192 - Vehicle Jounce or Vibration - 40 to 50 MPH - (F-250 Camper Special Units - 6900 Lb. or 7500 Lb. GVW)
  • Article 3193 - Vibration During Braking - Drum Brakes (THIS ARTICLE CANCELS AND SUPERSEDES ARTICLE NO 3115 OUTLINED IN TSB NO. 151, DATED 10/30/70) - Fairlane/Torino - 1970; Mustang, Maverick - 1970; Pinto - 1971 [Built Before 11/2/70])
  • Article 3194 - Universal Joint - Improved Constant Velocity - (All Bronco - 1966 thru 1970)
  • Article 3195 - Automatic Transmission - C4 - Drawn Out 1-2 Shifts/3-2 Downshift Cut Loose - CANCELS AND SUPERSEDES TSB 148, ARTICLE 3029C, SEPTEMBER 4, 1970 - (C-4 Automatic Transmission - All Applications - 1970-1971)
  • Article 3196 - Transmission Shift Selector Adjustment Procedure - (F-600 Trucks with C-6 Automatic Transmission - 1970-1971 [One-Way Rentals])
  • Article 3197 - Pinto Engine Tie Down Cables - 2000cc Engine - 1971)
  • Article 3198 - Cylinder Block - Tappet Bore - Revisions - (Pinto - 1600cc Engine - 1971)
  • Article 3199 - Improper Engine Performance - Camshaft Timing - (Pinto - 2000cc Engine - 1971)
  • Article 3200 - Push Rods - Oversize/Undersize - (302-2V Engines - 1969 With Positive Stop Rocker Arm Studs Only; 1970-1971 - All)
  • Article 3201 - Oil Leak - Engine - Rear of the Cylinder Block - 302 CID Engine - 1970)
  • Article 3202 - Oil Leak - Engine - Rear of the Cylinder Block and/or Oil Pan - (429 CID Engines - 1968-1971)
  • Article 3203 - Ignition Timing Marks - Econoline - (Econoline with 302 CID Engine - 1970-1971)
  • Article 3204 - Lack of Power & Engine Backfire - (401, 477, 534 Super Duty Engines - 1970)
  • Article 3205 - Coolant Level - (L-Series Trucks - 1970)
  • Article 3206 - Accessories Operate with Key in "OFF" Position - (Ford Equipped with A/C or ATC - 1971)
  • Article 3207 - Speedometer Service - Installation - (All Vehicles Except Thunderbird - 1971)
  • Article 3208 - Speed Control Sensor Binding Caused by Service Core-Tip - (Ford, Thunderbird with Speed Control - 1971)
  • Article 3209 - Power Windows and Air Conditioning System Inoperative - (Thunderbird - 1970-1971)
  • Article 3210 - Air Vent Control Binding and/or Noisy - (Mustang, Pinto with Standard Heater System - 1971)
  • Article 3211 - Vent Control Cable - Service Replacement - (Maverick - 1970-71)
  • Article 3212 - Windshield Scratched - L.H. Side - (Ford - All Models - 1971)
  • Article 3213 - Road Splash and Mud Accumulation at Door Entry Step - Light Truck - (F-100/350 - 1971)
  • Article 3214 - Front Door Window Noisy During Operation - (Ford Equipped with Outside Remote Rear View Mirror - 1971)
  • Article 3215 - Engine Cover Side Panel Cracks - ("W" Series Highway Tractor with Aluminum Cabs - 1967-70)
cron
