January 1970 - December 1970
Bulletin No. 132 - January 30, 1970 [COMPLETE]
(45 articles)
  • Article 2078 - New Special Bolt Head Design Tools
  • Article 2079 - Heater Output Insufficient - (All L, LT, LN and LNT with Gasoline Engines)
  • Article 2080 - Diesel Engine Ether Quick Start Mounting Bracket - (Louisville Series Truck Equipped with Diesel Engine)
  • Article 2081 - Brake Repairs - "Out of Round" Defect Code Superseded
  • Article 2082 - Parking Brake Valve - Air Exhaust at T-Handle - (L, LN, LT and LNT with Air Brakes - 1970 Model)
  • Article 2083 - Brake Pedal - Momentary Delayed Return - (All L, LN, LT & LNT Series with Air Brakes - 1970 Model)
  • Article 2084 - New Air Compressor Bracket and Idler Pulley - (C-6000-8000 With Caterpillar V-8 Diesel Engine - 1968-1970)
  • Article 2085 - Front Suspension Caster Specification Change - (1970 Thunderbird and Ford)
  • Article 2086 - Driveline Roughness Due to Incorrect Pinion Angle - (1970 Mustang - Early Production with Base Suspension)
  • Article 2087 - New Power Steering Pump - (THIS ARTICLE CANCELS AND SUPERSEDES ARTICLE 1898) - (All "W" Series with 8V-71 Engines)
  • Article 2088 - Rear Axle - Replacement of 9-3/8" Ring Gear Two Pinion Axle Assemblies with 9" Four Pinion Axle Assemblies - (1970 Ford and Thunderbird)
  • Article 2089 - Differential Lock-Out Inoperative - (LT & LNT Trucks with Air Operated Differential Lock-Out - 1970 Model)
  • Article 2090 - Exhaust - Interference Between Stack and Off Chassis Vertical Pipe - (Louisville Series Trucks Equipped with Dual Exhaust Stacks - 1970)
  • Article 2091 - New Pistons and Piston Rings to Improve Oil Economy - (All Medium, Heavy and Extra-Heavy Trucks with 330, 361 and 391 C.I.D. Engines - 1970)
  • Article 2092 - Driveline Vibration - (LT 800, 8000, and LNT 8000, 900 and 9000 - 1970)
  • Article 2093 - Driveshaft Center Bearing New Adjustable Support Plate - (L-800-900 and 8000-9000 Trucks - 1970 Model)
  • Article 2094 - Automatic Transmission - Non-Adjustable Vacuum Diaphragm - (All 1970 Vehicles with C4 and C6 Automatic Transmissions)
  • Article 2095 - Automatic Transmission - Accessory Oil Cooler Kit - Trailer Towing Severe Duty - (All 1970 Passenger Cars and Light Truck with Ford Automatic Transmissions)
  • Article 2096 - Automatic Transmission - 1970 Oil Level Indicator - (All 1970 Vehicles with Ford Built Automatic Transmission)
  • Article 2097 - Automatic Transmission - Delayed Reverse Engagement or Erratic Kickdowns - (All 1970 C4 Automatic Transmissions Except Falcon)
  • Article 2098 - Dual Gasoline Fuel Tanks - Fuel Tube Routing - (Louisville Series Trucks - 1970)
  • Article 2099 - Fuel Tank Selector Valve Reduced Fuel Flow - (All L, LN, LT & LTN 500-900 with Dual Fuel Gas Tanks - 1970)
  • Article 2100 - Fuel Tank Crossover Line Routing - Length - (All "L" Series Trucks Equipped with Diesel Engines & Dual Fuel Tanks - 1970)
  • Article 2101 - Accelerator Pedal Response Improvement - (1968-1969 Fairlane with 302-351 CID Engines Regardless of Transmission)
  • Article 2102 - Engine Oil Loss Due to Filter Puncture - (1969 Mustang with 302 or 351 C.I.D. Engine)
  • Article 2103 - Air Compressor Coolant Line Routing - L Series Truck - (L & LN 9000 Series Trucks Equipped with 8V-71 Detroit Diesel Engine - 1970)
  • Article 2104 - Air Cleaner Element Collapsed - Dorset Diesel Engine - (Dorset 242 and Past Model 220 Dagenham Diesel Engines P-3500/5000 Trucks)
  • Article 2105 - Lower Radiator By-Pass Hose Kinked - L Series Trucks - (Louisville Series Trucks with Detroit 8V-71 and Cummins Diesel Engines - 1970)
  • Article 2106 - Radiator Top Support Rod Mounting - L Series Trucks - (All Louisville Series Trucks - 1970)
  • Article 2107 - Engine - Lack of Power - (All L, LN, LT and LNT with 330, 361 or 391 CID Engines)
  • Article 2108 - Air Cleaner Inlet Restriction - Loss of Power - (Louisville Series Trucks Equipped with Cummins NTC-335 Diesel Engines - 1970)
  • Article 2109 - Battery Splash Protection - Behind Cab, Frame Mounted - L Series Truck - (Louisville Series Trucks - 1970)
  • Article 2110 - Autolite Alternators - Improved 65-85 Ampere - (Medium-Heavy-Extra Heavy Trucks)
  • Article 2111 - Fuse Panel Cover - Difficult Closure - ("L" Series with Line-Haul Instrument Panel - 1970)
  • Article 2112 - Turn Signals, Stoplamps, and/or Horn Inoperative - (All Vehicles with Tilt Column - 1970)
  • Article 2113 - Speedometer Cable Breakage - (LT & LNT Series with Dana 7231-D Auxiliary Transmissions - 1970 Models)
  • Article 2114 - Electric Windshield Wiper Kit - (Bronco All with Vacuum Wipers - 1969 and Prior Models)
  • Article 2115 - Power Windows Stick in the Up Position - (1967-1969 Thunderbird and 1969-1970 Ford)
  • Article 2116 - Horn Inoperative with Tilt Wheel in Lowest Position - (Thunderbird, Ford Mustang with Tilt Column - 1970)
  • Article 2117 - Oil Pressure Indication High - (Mustang with 351C Engine - 1970)
  • Article 2118 - Door Glass Pulled From Channel - (SUPERSEDES ARTICLE NO. 2045 IN BULLETIN 130) - (1969 Carlines Using Bonded Door Glass [Most Hard Top Models])
  • Article 2119 - Seat Back Angle - Excessive - (1969 Ford Equipped with Recliner Seat)
  • Article 2120 - Front Stone Deflector Attachments Loose and Rattles - (Fairlane - 1970 All Models)
  • Article 2121 - Paints Availability - Thunderbird R.P.O. Glamour Colors - (1970 Thunderbird)
  • Article 2122 - Splash Shield Retention - Fender Inner Panel Extension - ("L" Series Truck - 1970)
cron
