January 1970 - December 1970
Bulletin No. 134 - February 27, 1970 [COMPLETE]
(31 articles)
  • Article 2156 - Sure Track Brake Systems - New Special Service Too for Companion Flange Rotor Installation - ( 1970 Thunderbird)
  • Article 2157 - Upper Arm Lube Kit - Modification - (1965-1970 Light Cars and Thunderbird)
  • Article 2158 - Air Brakes - Moisture Ejector Valve Installation - (All "L" Series Trucks with Air Brakes - 1970)
  • Article 2159 - Automatic Transmission Specifications - (All Vehicles Equipped with an FMX Automatic Transmission)
  • Article 2160 - Automatic Transmission - Oil Pan Screen Assembly - FMX - MX - (Ford, Mustang, Fairlane and Truck with FM or FX Transmission - 1969-70)
  • Article 2161 - Automatic Transmission - Front Servo Body - FMX - (Ford, Mustang and Fairlane - 1969-70)
  • Article 2162 - Automatic Transmission - Rear Servo Cover Seal Leak - C4 - (All Models So Equipped)
  • Article 2163 - Automatic Transmission - Delayed Reverse Engagement - C6 - (All Models So Equipped)
  • Article 2164 - Carburetor - Stalling or Stumbling During the First Few Miles of Cold Weather Operation - 351-2V-C - (Torino and Mustangs with 351-2V-"C" Engines - 1970)
  • Article 2165 - Carburetor Hesitation on Light Throttle During Warm Weather - 429 CID - 4V - (Passenger Cars with Automatic Transmission - Early 1970)
  • Article 2166 - Cylinder Head Valve Guide Repair - (Reference: Special Service Letter 83, 7/21/69 - Special Service Letter 83 Supplement, 10/22/69)
  • Article 2167 - Crankshaft Seal - "Split-Lip" Type Rear - All 144, 170, and 200 CID Passenger and Truck Engines; and 429 and 351 CID Passenger Car Engines)
  • Article 2168 - Oil Pressure Specification - Revised - (351-C CID Series Engine - 1970)
  • Article 2169 - Exhaust Manifold Breakage - (289/302 Engines - 1965-1970)
  • Article 2170 - Induction System Vacuum Leak with Rocker Arm Covers Removed - (All 429 CID Cobra Jet Engines)
  • Article 2171 - Push Rod Assembly Identification - (Fairlanes Equipped with 429 CJ/429 SCJ - 1970)
  • Article 2172 - Oil Leak - Rear of Engine - (429 CID Engines - All Units So Equipped)
  • Article 2173 - Oil Pan Gasket - Replace - (Fairlane 429 CID 8 Cylinder)
  • Article 2174 - Battery - Cable Clamp Corrosion Prevention - (All Units with Ford-Autolite Batteries - 1967 to 1970)
  • Article 2175 - Alternator Warning Light and/or Accessories on with Key Removed - (All Cars and Trucks with Ford Alternators - 1970)
  • Article 2176 - Bulb Chart Revision - 1970 Car Shop Manual and 1970 Specifications Manual - (All 1970 Car Lines)
  • Article 2177 - Roof Marker Lamp Lens Replacement - Supersedes Article 1906 TSB No. 120 - (1969 F-T-N-C Series Trucks)
  • Article 2178 - Turn Signals Inoperative or Erratic - (Vehicles with Tilt Steering Column - 1970)
  • Article 2179 - Transmission Selector "PRND21" Light Inoperative or Intermittent - (Thunderbirds with Tilt Column - 1970)
  • Article 2180 - Heater Hose Installation - (Passenger Cars - All 1970 and Past Models)
  • Article 2181 - Radio Ignition Noise Suppression - (Thunderbird with Hydraulic Windshield Wipers - 1970)
  • Article 2182 - Air Conditioning Condenser Mounting Screws Loose - (Mustang - 1970)
  • Article 2183 - Speedometer System Failure Involving Sensors - (Ford and Thunderbird - 1970)
  • Article 2184 - Moulding - Body Side Vinyl Inserts Loose - (All Vehicles So Equipped - 1970)
  • Article 2185 - Wind Noise and Water Leaks - Under the Passenger Side of the Instrument Panel - (Ford Models with Distributor Modulator System - 1970)
  • Article 2186 - Hood - Hinge Springs - (Fairlane - 1970 All Models)
cron
